Oil pressure issue with new ERL 434ci engine.
The 30 seconds with little to no oil pressure is not what killed it. It the miles after you had some. The thrust got killed because the bearing was dead. They need oil, Path of least resistance.
Prelube is a must. You really need more oil pump and also need to make sure the pump is installed correctly. Sounds like you may have some pan issues also.
Hope you didn't kill the main caps with heat like mine did.
Tim
Tim
You had oil pressure because you had 20-50 in it. that is thick stuff. If you would have had 10-40 in it it would have been a different story.
If you didn't take the pump appart to center it to the hub it was wrong. 1/2" is too much pickup clearance.
Rolling the engine over to get oil pressure is asking for problems. you can make a preoiler really cheap that you put air pressure to and it pushes the oil thru the engine.
Honnestly I would look very very close at the pump pick up tube and pan that you are running. If things are not prefect you will have more problems.
The pump needs to be inspected now with all the trash in the oil anyway.
Tim
Tim
Tim
Tim
Also, with the pump being the wrong one..if that was the case why would they recommend it? I would of spend the extra money for a different oil pump if thats what they suggested. Clearly the pump was doing its job and had it not of been for the wiped out bearings the oil pressure would of beem fine. And you are right about the thicker oil and higher pressures..that was the point I was trying to make. If driving the car caused these issues then I would of seen a higher oil pressure in the beginning. I ran the 10w40 on startup..changed the oil and the oil pressures remained the same from when I had 0 miles on the motor till I took it apart leading me to believe that the oil pressure issue was there from day one.
On the first actual startup I let the car go all the way to operating temp and thats when I noticed the 15-18psi on the 10w. I shut it down changed the oil as I usually do, Let the car warm up to operating temp again and at that point it was around 22-24psi..and after a 5 mile drive it was down to 18psi...which is where it remained the whole time.
Im hoping my cam and cam bearings aren't wiped out as well. Before this i've never even known of there being a barbell plug in the back of the block. I sent my engine out with it and got it back without it. Every time Ive had my engines done id send the block with out them and get them back with them installed and never had the issue before. =(
I sent them my block to resleeve with the plug installed. They send me back my resleeved block with the plug missing which is why I didn't catch it..or even think to look for it. And I knew better than to keep driving it. The mellings pump would work just fine on a factory LS2 block. Just the sleeves were upgraded, not the oiling system..so to say the pump isn't enough is just wrong. The crank will need to be polished..it really didnt look too bad. Even the thrust surface has very minor surfacing markings.
#32
Yes, I've had 4 motors built in the past 8 years and ive always unhooked the coils and the injectors and turned the motor over usually seeing oil coming out of pushrods within 30 seconds. This time I saw no oil but figured(and was told) it was because I didn't soak the lifters and they needed to fill up. I was also told by Seth at ERL that using that method would be fine. I was even told by him letting the engine run for 30 seconds that way shouldn't of caused any damage that these motors can take a beating.
#33
LS1Tech Sponsor
The bearings were probly shot from the first startup. It happens and we've seen it a few times.Between dry cranking it(no barbell) and then starting with no barbell I would probly point to that as the cause.
FYI- We ussually prime the engine on the stand before install - pour oil into the oil pickup while turning the motor by hand. Then just fire it in the vehicle. Haven't had an issue doing this.
#34
Well I emailed ERL this morning and waiting on a response. If they will provide me with new headgaskets and bearings I will gladly pay my guy to rebuilt thus putting any future "warranty" issues on him. I feel as though its fair enough. I will have to shell out another 500$ in labor though.
#35
Update. Finally got a response back from ERL and they have agreed to provide me with new bearings and new head gaskets. Needless to say despite the fact that my motor is toast and is going to cost me money I am more than happy with the agreement. I will still have to spend about 500$ in labor which to me is justified since I didn't check for the plug, regardless of if I knew about it or not, before putting it together.
#36
I received my AES 390 long block a while back and did everything these guys on this forum say to (e.g. center my pump, check for clearance on my pick-up and bottom of my oil tray etc.) Well, when I went to prime my engine while on the engine stand with a starter I did not get any oil pressure. What I did then was fill the **** out of it with oil and then tried again, which finally did the job. Now that I'm finally getting my stuff (Lonnies double pump system, 80 ib injectors and Aster bracket) I hope I dont have any issues when I fire up my engine for the first time!! I've invested so much money at this point that I'd probably drive off a cliff. Also I don't understand some of these people who say you should'nt crank your engine to prime your engine if that's what we've been told by our engine builders???? I hope all ends well for you bro!!
#37
#39
...can't wait to see how this turns out. Boy is your wife gonna be pissed.
