The problem is that crackles fall off valve?
Old 05-26-2012, 04:22 PM
Hallenborg's Avatar
Default The problem is that crackles fall off valve?
Hello I have a problem with my Chevy engine twin turbo.
I have an LSX block with warhak heads and an original cam and stiffer valve springs.
first time it was on an exhaust valve. when the valve stem had been gnawed by the crunch. After that we changed brands. and this time it has an intake valve keepers fallen off.
I lathes 6400rpm max.
and I charge a maximum of 20psi (1200hk 1633nm)
and when this happened I loaded 10 psi (750hk and 1200nm)
What can cause this problem?
it may be rpm stop?
boost pressure?
Regards
Jonas Hallenborg
Sweden
Old 05-26-2012, 06:33 PM
96 Comp T/A's Avatar
Any pictures to better illustrate what you are talking about?
Old 05-26-2012, 08:53 PM
S10xGN's Avatar
Hmmm, something's getting lost in the translation...
Old 05-27-2012, 08:08 PM
outkast6991's Avatar
Sounds like he's chewing up valve tips but I'm no expert in Swedish
Old 05-27-2012, 09:07 PM
He didn't say specifically, but if the OP is using titanium valves, typically lash caps are used to prevent wear and tear. Definitely in need of pictures or a better description of what is occuring.
Old 05-27-2012, 11:12 PM
Adam Connell's Avatar
Contact CamaroAndreas on here: https://ls1tech.com/forums/member.php?u=99114
He is from Sweden and can help you. He has a VERY fast 2000+hp twin turbo car.
Old 05-28-2012, 12:55 AM
slpfirehawk415's Avatar
Yea pictures would help but I was thinking, it sounds like you are possibly saying that the valve looks chewed up where it seals to the head. If this is the case it could be caused by heat and the pressure dropping causing the valve to burn. Better valves, like something sodium filled, could solve a problem like that.
Quick Reply: The problem is that crackles fall off valve?
