Which gasket for my Ls2?
The first guy said: Bore: 4.130 with a .060” thickness would yield an approximate compression ratio of 9.55:1. Bore: 4.130 and .070" thinkness will result in a slightly lower compression ratio of 9.36:1.
the second guy said It would require a .080 gasket which is really thick so we don't recommend it. , also, it would be custom
So which one would get me to my goal? thanks for your help
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
http://www.texas-speed.com/p-2129-gm...ividually.aspx
