LS2 in Burned out Trailblazer SS
Uh huh...
A trip to the car wash, a couple cans of Gunk........Like new!
This thread is comical to me.
Y'all know that external fire didn't get hot enough effect any of the metal in that motor right? It gets way hotter inside the combustion chamber than anything that was burning under that hood. Most of that stuff on top of the motor is the insulation from under the hood, it's designed to act as a fire blanket in those situations. The big plastic fasteners melt and it drops down and smothers the fire on the top of the motor. I will bet a Yankee Dollar that you can clean that thing up down to the long block, swap over the intake and controlls from another vehicle and that motor would run flawlessly for a couple of hundred thousand miles.
#32
#34
It didn't get anywhere near that hot. Aluminum melts at a little over 1100 degrees, if it had gotten that hot the block would have slagged into a blob. I know a guy right now reused a motor from his 2001 Camaro SS that Burnt up. It's now in a FRC Corvette and makes a thousand HP at the rear wheels.
#35
Buy it for $100. Send a head in and see if it's straight. If it is, then It might be salvagable. Remove the internals and have the block checked for warpage. If it's messed up, then recover your $20 in aluminum.
#36
Even then I would still take a chance for 100 bucks.
In this situation its the length of time of the burn. If it was on fire for 2 or 3 minutes then somebody put it out it might be ok to tear down and rebuild into something. If it was on fire on the side of the road for like 20 minutes straight until a fire truck could get there and put it out, then i wouldn't chance it.
#40
