6.0L ls3 heads (which gaskets?)
Old Jul 1, 2012 | 11:32 PM
flynlow3's Avatar
Default 6.0L ls3 heads (which gaskets?)
I have searched with no definate answer. Can someone tell me which gaskets I will need to use?
I have a 6.0L iron block that is bored .30 over and a brand new set of ls3 heads. I will be assembling as soon as I get it back from the balancing shop and need to know which head gaskets to run. Also,
I plan to go with ARP head bolts. Which set? Can someone point me in the direction of a part number?
Please and thank you!
Old Jul 1, 2012 | 11:49 PM
zummo's Avatar
I would use lsa-ls9 gaskets if it was mine, Here is the lsa-ls9 gasket part# 12622033 if you want it. If you are gonna boost it or spray it.
Old Jul 1, 2012 | 11:56 PM
1badeagle's Avatar
I used stock ls3 gaskets from scoggin dickey
Old Jul 2, 2012 | 08:10 AM
Gray86hatch's Avatar
I used 6.0 ls2 headgaskets.
Tim
Old Jul 2, 2012 | 04:33 PM
3pedals's Avatar
I used 4.00 x .040" cometics
Old Jul 2, 2012 | 04:40 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Use LS3 gaskets. As for the bolts, what year is the block? It's fairly assumable that it's the old style block and needs ARP 134-3609.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
