To vvt or not to vvt
2) How many things have manufacturers done throughout the years that turned out to be just a fad? Its like saying everyone's doing it so it must work. I got rid of DOD and VVT and the car made more power, back to back apples to apples...period, in my experience its all marketing.
Also, we need good data. I realize most folks aren't going to take the time or money to compare cams, but its really the only way to get a clear picture of what parts "actually" do and don't make power in each application. Posting up a graph saying I made xx power more vs my stock cam isn't helpful...you could have made the same (OR MORE) power increase by using a non-VVT cam. I am just trying to provide honest real world experiences on the topic.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
I think the real question is if the gains are worth the additional costs and whether or not the LSx VVT system will prove reliable in performance applications. My biggest concern with the VVT setup I'm pursuing (TSP VVT-2) is how stable the cam valve timing will be and whether or not that will cause problems with valvetrain control. As long as the timing control is good, you could theoreticaly grind any cam profile onto a VVT core and see the benefits of on-the-fly timing adjustment.
Futureuser, you should have Vengence grind your cam profile on a VVT core, do a swap and let us know what the gains are after cam timing optimization
I bet you could do it for less money than I'm spending to fix my rust pile lol. I think the real question is if the gains are worth the additional costs and whether or not the LSx VVT system will prove reliable in performance applications. My biggest concern with the VVT setup I'm pursuing (TSP VVT-2) is how stable the cam valve timing will be and whether or not that will cause problems with valvetrain control. As long as the timing control is good, you could theoreticaly grind any cam profile onto a VVT core and see the benefits of on-the-fly timing adjustment.
I bet you could do it for less money than I'm spending to fix my rust pile lol.Did these cars have the VVT software tables installed from companies such as TSP who have spent countless hours and hundreds of dyno pulls refining the VVT software for their cams? Were they just using the factory tables?
