Engine Build for 69 Camaro and New to LS World
I want to have around 550hp at the wheels. From some of the research I've done so far I want to find a junkyard LQ4/9 complete and then add L92/LS3 heads. That's about as far as I've decided on stuff so far.
I want to keep the engine carb'd and my camaro already has a muncie 4 speed in it with 12 bolt rear end. I was wondering if anyone has done any LS swaps into 1st gen camaros and what is all involved? I know I will need to get the MSD ignition box for this conversion. Will I be able to hook the LQ4/9 up to the muncie? By staying with a carb and only having to do the ignition box what sensors will I need to keep in the LQ4/9? Can I keep the same fuel system setup that's stock in the camaro since I'm staying with a carb?
I am still in the planning stages right now. Just want to make sure I have a plan so I get all of the right parts. Any other input you guys have would be greatly appreciated.
Hooker makes some swap headers as well as motor mounts. Hell even GM now makes a conversion pan for the early models. Do some research on accessory drive parts - not sure all will clear stock front sub frame.
Make sure to add up all the parts costs before pulling the trigger. As you now have a SBC car don't loose sight of a stroker version of the old guy - $10K can get you pretty close to 600 hp in a crate motor. You could have this in and be driving in a day.
Quick time bell housing #QTI-RM-6036
Hooker motor mounts # HOK-12624HKR
Good luck with your project!
I was just saying LQ4 with L92 heads as a start towards a 408. I would build the rest of the engine but don't know yet what else I would all go with yet. That's what I'm doing now is planning it all out and how much I will have spent in it. I know the crate engines are reasonably prices and have a lot of power but I would like the satisfaction of "I built this" type of feeling.
For carb vs injection I think it would be cheaper to stay with a carb since that would just be intake and ignition module for me rather than the expense of converting to injection.
Those prices say they come with complete engines that include accessories. I'm all open for money savers and input. Any help is much appreciated.
Tsnow has a good write up with pics on his. There is 6-7 others that update often also. There is a sticky just for conversions on our cars. Lots of good info.
I will go with LS3 heads then. I didn't know that, I thought they were the same.
If you get an lq9 you will have to buy the new heads new springs, new gaskets etc. you will have new heads but honestly there really shouldnt be any significant wear on a lower mileage engine like the ly6. In the end the ly6 may even bea tad cheaper, you will also get the benefit of vvt which means you can run a larger cam and still retain your down low grunt.
I'm set on a carb because I want to keep the old school "no computer" kinda feel to the car. I know the ignition and that is computerized. My dad is a mechanic who I have learned all of my car skills from and my little brother is finishing up school for high performance to work on drag cars so they both have a good knowledge of carbs. I view tuning a carb easier than tuning fuel injection since I can do it myself. I've also read that it can be expensive to convert over to fuel injection (the rest of the car).
How much did you get the bell housing for? Summit is showing it for $578 didn't think it was that expensive....
