Thermostat interchanability
Old Jul 9, 2012 | 11:24 PM
Jeep09's Avatar
Default Thermostat interchanability
Does anyone know if Stant makes a 180 or slightly less thermostat for the LS1? iIseen one on EBAY PN -14698 but its sounds sketchy if its a fit.
Old Jul 22, 2012 | 05:59 PM
stevieturbo's Avatar
You can get 160DegF stat for an LS1. The stat is integral to the housing. They arent overly cheap though.
Old Jul 22, 2012 | 08:35 PM
S10xGN's Avatar
The integral housing one? You can disassemble it and stack a few shims under the shaft. IIRC, I used two 3/16" pop rivet washers and ended up at 170°...
Old Jul 24, 2012 | 12:40 AM
Jeep09's Avatar
Thanx, will give it a try
Old Jul 24, 2012 | 07:41 PM
S10xGN's Avatar
This thread will help. He used pieces of rod inside the hole, I used shims (small washers) over the rod. Just a different method of accomplishing the same thing...
