Will the LS9 cam work with an Iron 5.3L?
Thinking of dropping the ball on the ls9 cam for a budget turbo build. will it work. seems like i heard its a 3 bolt. not sure really. too lazy to search right now.
Don't see why not. Denmah on here did it with a 4.8L
https://ls1tech.com/forums/forced-in...-fairmont.html
Not sure where the cam sensor pickup is on that block but the LS9 cam only has the provision for a cam sensor on the timing cover, not the top back of the block. Also not sure if it's a 3 bolt or 1 bolt.
