Beware of LSX Long blocks!!!!
Look at your oiling system and was the engine prelubed prior to starting .
Tim
To answer the question about how did Tune Time know it was the thrust bearing yes Tune Time dropped the oil pan which involves taking the whole front end apart and they inspected the engine from underneath. That's probably why the dealer didn't even mess with it. Listen I'm 100% with you guys that something drivetrain related put pressure on the crank and caused that bearing to go I understand that, my problem is that even if I had a 100000000 dollar top of the line TC installed by Tune Time in the first place and say it was just a rod bearing and not the thrust bearing IT WOULD NOT BE COVERED.
Bottom line they are selling aftermarket engines encouraging people to mod them and then saying a aftermarket TC will void your warranty no matter if it caused the problem or not just like if you put any kind of forced induction on the car. There is actually a list they told me of parts that will void your AFTERMARKET engine warranty. Call me crazy but if you sell a aftermarket engine unless what you put on caused the problem or contributed to something else that caused the problem I don't think you should be beat when something goes wrong. I'm not on hear looking to get even or bash and it's not that big of a deal to me where I"m on a GM witch hunt but I do think that the TC voiding the warranty even if it's not related to the damage of the engine is worth letting everyone know about and that it's not worth the risk cause we all know that just about everyone with this engine has a aftermarket TC.
I would of asked the dealer what converter wouldn't void my warranty if thats the case.
Edit: I just found a GM Performance Parts TC, its only 2500 stall speed, but who wants that?
In my experience with GM crate engines LSX or any other for that matter they require a complete tear down and blueprinting as soon as you get one and then they work great. Theres always something not quite right with them if you pull them apart and even if they dont fail straight away they dont last long unless you spec them out yourself ( or have a reputable shop do this ) which speaking of which.... most reputable shops should know this needs doing after past crate engine experience..... Most of these engines are made in Mexico too.... just sayin
Thanks man. This won't keep me down long I cant wait to get this thing back on the street again
Probably because it's not true - not ONE person I know of with a crate LS engine has had to tear it apart or it to fail within a few hundred miles
However, on the other, I have had NOTHING but problems when I buy 'built' engines from builders who are supposedly the best.
Crate engine is the way to go for cost, timeliness and reliability imho.
