LS2 Block which Valley Pan (PICS)
Old Aug 1, 2012 | 07:09 AM
McAllister513's Avatar
Default LS2 Block which Valley Pan (PICS)
Ok I picked a good aluminum LS2 block that I have took to the machine shop to be honed and cleaned up. I'm in the process of ordering parts to get this build going and wondering which valley pan I should use. The part number says the block was a 05 model but I do not know what it came out of. It does have to holes in the valley area like the L92 blocks and such. I have read that I can use the LS3 valley pan Part #12599296 is this true.
Old Aug 1, 2012 | 08:10 AM
Gray86hatch's Avatar
Ls3 cover will work
Drill and tap the towers for 1/8 pipe plugs
Tim
Old Aug 1, 2012 | 09:26 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
LS2 and LS3 valley covers are identical except for the fitting that breathing fitting that comes out the front....the fittings are in the same spot, but with a different style fitting on each.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
