Why so much timing with my Blown LS3?
Any help understanding this would be appreciated
Intake duration and ICL determine DCR.
28* is IMO way to much for a boosted motor even on race gas especially a power adder like a roots that pretty much super heats the intake air coming into the motor.
I'd be around 18*-20* on race gas with a set-up like that and 12-14* on pump gas.
IMO its way too much also, but why is it taking so much is what i dont understand. What can be done to lower it without losing power? When its set at 18-21 the car just doesnt make the power
But the intake valve close event has everything to do with compression.
The compression stroke happens when the intake valve is closing. When and where that intake valve closes determines how much pressure is captured in the combustion event. Adding intake duration makes the intake valve close later thus reducing DCR and reducing intake duration makes it close earlier thus trapping more cylinder pressure in the cylinder earlier as the piston rises up in the bore on the compression stroke.
When you advance or retard the ICL it advances or retards that IVC event along with all the other valve events.
Exhaust valve open and close happen after the compression stroke therefore not having any effect on compression.
Hope that makes sense.
I would advance it at least 4 degrees if not closer to 6 degrees.
And yes if it were on a 116+3 I would like the valve events much better.
Just interested as I have the GT9 in mine now
I certainly cant throw timing at mine like this guy is doing though.
I'd almost query if the numbers he is quoting are correct, and they should be verified with a timing light.
But it would take an incredibly bad profile to no produce results in an LS. The GT9 is a good camshaft and has been proven in different engines. I'm certainly very pleased with it in mine.
It idles super smooth, it revs and makes good power.
Maybe try a different tuner, and as said, verify 100% the timing you think you have, you are actually seeing at the plug.
