whats the best LS3 cam ?
Double row timing chain
Hardened pushrods
Valve springs & retainers
90mm throttle body
Ram Jet OTRCAI
WA Performance MAFLESS tune
25% under drive
1 7/8" into 3" headers
3" section to 3" cats
Twin 2 1/2" exhaust system
Gearbox,
Stock 4L60E
Allfast 9 1/2" convertor
Diff,
4.1:1 diff gears
Wheels
Stock 18" x 8"
Tyres
Front 225/40/18
Rear 265/40/18 Mickey Thompson
As it is sitting on the rev limiter some 40 yards before the line I am looking at trying 274/45/18 M&H tyres soon.
The last pass I made I let the car shift into 4th gear which lifted the speed up from previous 120.xxmph to a little over 121mph so it may have enough power to use the taller tyre.
Here is a link to it on our webpage:
http://www.texas-speed.com/p-79-texa...-camshaft.aspx
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
This same converter with the LS3 is stalling to at least 4,500rpm.
I've changed the setup since then but yeah with the filter.
The old LS1 that I sold out of our car last year had the limiter set at 6,950rpm, the new owner went circuit racing with it and broke number 6 rod with a lower limiter.
A good friends GTO with a LS3 headed LS2 also broke a rod earlier this year with the limiter set at 7,200rpm.
Main reason for not lifting the limiter though is that the current combo is already flatlining.
its a 111 lsa tho some ppl dont care much for that
