Iron block LS3 piston clearance?
Old Aug 8, 2012 | 06:04 PM
nobreaks254's Avatar
Default Iron block LS3 piston clearance?
I am building an iron block ls3 using stock ls3 pistons and rods with a lq4 6.0 block. What I am wanting to know is what the piston clearance should be? Anyone?
Old Aug 8, 2012 | 06:24 PM
KCS's Avatar
KCS
Moderator
I'd have to double check my build sheet, but I think I put mine just under .002". So far so good.
Old Aug 8, 2012 | 06:51 PM
Interesting build. If you get a chance to check your build sheet,that would be great. I was thinking more like .003, 2 seems tight to me. What rings did you use?
Old Aug 9, 2012 | 07:08 AM
KCS's Avatar
KCS
Moderator
.002" is on the high side of the production limit, and since they're cast hypereutectics, they won't really expand much, but since I plan on hitting it with some nitrous I felt it would be perfect. I ended up putting them all in at .0018-.0020".
For rings, I used Hastings rings from Nook and Tranny. I'd recommend them any day. They're inexpensive and use a Napier second ring with a plasma moly top ring. For $150, they're hard to beat.
