VVT Timing Chain
Old Aug 24, 2012 | 06:35 AM
LongIsland63SS409's Avatar
Default VVT Timing Chain
Does anybody sell or is developing a double roller chain for a VVT setup?
Thanks,
Mike
Old Aug 24, 2012 | 07:19 AM
85MikeTPI's Avatar
No, not that I'm aware of. I purchased a Katech chain for my VVT.
Old Aug 24, 2012 | 11:44 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Unfortunately, I have not heard of anybody making (or even working on) a double-roller for the VVT setup as of yet. Like mentioned above, you can run the aftermarket single chains to beef it up some!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 24, 2012 | 01:32 PM
litle88's Avatar
No need for double roller chains bud, a katech is more than enough. I'd worry more of harmonics and that chain tensioner (if it's on the Vvt's) and switch to an Ls2 dampner and a good balancer and you should be good.
Old Aug 24, 2012 | 06:47 PM
Thank you for the responses.
I did'nt know Katech was an option.
Will purchase the upgraded chain.
What is required to install the LS2 damper?
I have a 2008 LY6 cast iron block.
Are the holes drilled and tapped already?
In about 3/4 weeks I'll be installing the Texas Spped VVT3 cam I purchased from them in March.
I'll have the front cover off by then so I will have a better idea.
Thanks for all the help.
Mike
Old Aug 24, 2012 | 07:54 PM
85MikeTPI's Avatar
http://www.enginebuildermag.com/Cont...0000054947.pdf
The single bolt cams have asymmetric timing gear teeth, which is why they moved to the spring loaded tensioner that everyone hates on.. I chose to stick with the LS3 tensioner, but YMMV..
