GM MLS LS9 Head Gasket Questions
Before I set down my new head gaskets and torque them to spec I have a few questions. I have a 2005 LS2 that I am installing heads, cam, and a Maggie (10lbs of boost) on. I pulled the heads to install new lifters, and have some light port work done. They took off .004 when they shaved them, and they are supposedly totally flat.
I purchased a set of GM MLS 7 Layer Gaskets from GM Parts House. I have never installed head gaskets on an LS motor before. In addition I purchased a set of ARP Head bolts.
Last Gen I small block I used Indian Gasket Sealer on. I am getting mixed reviews on GM Gaskets in general. Some say to use copper sealer between layers, others are stating put them on dry.... I guess a good place to start is to ask how GM installed them, if anyone knows?
Second question is on the ARP head bolts. They call for 25ft/lbs for the small bolts and 75 ft/lbs for the large bolts, tightened in three equal amounts. So I am thinking this is 6/12/25 and 25/50/75? I have a standard Clicking Snap-on Torque wrench, is this suitable?
In addition I am using the ARP lube... do any of these bolts go through water jackets where I need to use specialized sealer in addition?
Last question, do ARP bolts need to be re-torqued after a certain Mileage?
If you guys could provide me with any good information, tips, or tricks (an LS2 tightening sequence would be nice as well) It would be greatly appreciated!!!!
Thanks,
DG
Thanks,
DG
I install head gaskets dry with no issues at all, clean and prep block surface, remove gasket from package and set on block.
Head bolts do not require special sealer? And yes you are correct in your thinking about torque specs.
Unfortunately I don't have the torque sequence or else I'd post up.
