Cleaning Deck Surface for New Head Gaskets
After I did that, I put the heads on, torqued them down, and poured more cheap oil through everything, drained it all again, filled it with good oil, and I've put around 20K miles on it since.
I prefer to use a shop vac to pull stuff out of the cylinders if it gets in there...just use a narrow cone attachment, it will pull everything out as long as you don't turn the engine over and bind stuff into the rings. After doing that, and before putting the heads on, I wipe some motor oil onto the cylinders from my fingers and turn the crank over.
I also roll up paper towels into really tight rolls and slide them into all of the head bolt holes, and let them sit for a while, to be POSITIVE there's no water/oil in there. After I think they're dry, I do every hole 1 more time. It's worth an extra roll of paper towels to know I'm not going to crack the block putting a head bolt in.
Not saying what I do is "right" or "the best" way...but it's always worked for me. I've only lost bearings on one engine, and it was due to insufficient baffling on a road course causing the oil pump pickup to go dry at 6500 RPM.
I've seen people use the coarser grades to clean decks for MLS gaskets without failure, but I personally use the greys with engine oil on them to catch some of the particles that otherwise might have become airborne. Then clean up the mess with blue shop towels, or even better lint free cloths, either one soaked in brake parts cleaner or lacquer thinner.
Start the engine and change the oil / filter within a few minutes of run time to remove inevitable particles that have migrated to the oil system.
So many comments yet not one helpful "safe" suggestion yet. You can't blame those of us with less experience for trying. Especially since we are all trying to do it correctly. Its hard to with the limited information there is out there, and most of us aren't born with all the answers unfortunately.
DG
Easy to make macho claims on simple tasks, even document it with pictures and post it on forums.
Bottom line is - how long will your built last!!!
My suggestions are not my "right way" as to proper tools/methods, rather, it is the accepted, very basic "right way" in good shop practice and cleanliness control!
This is what you posted:
1. Post 12 - you suggested Bristle disc.
2. Post 17 - one of the three suggestions was shop air.
Rubbed you in the wrong way huh!
I am not here to educate you and I am moving on!!!
Aloha!!
I don't know if you are aware of this or not, but proper engine building isn't dropping your car off at the local speed shop, handing them a boat load of money, and then picking it back up two weeks later with supercharger and cam bolted on.
And for the record I spent a number of years working for a dealership where whiz wheels were used daily and still are to clean these parts. So beware of the care not taken when you drop your car off to that supposed "specialty shop" of "experts."
Rant over
DG
Rant over
DG
Funny how people always try to impress by saying they have so many years working experiences....and yet not accepting they'd been on the wrong track!
1. On CF - I posted "don't use razor blade and scotch brite" from the get go, also explained that can cause leak paths...don't use anything harder than the base material....use only chemicals...if you want to scrape, use purpose built hard plastic...... and what did you do???
2. Over here - warned you about "Bristle disk also contains abrasive particles. Shop air will force particles into crevices." Do you know what abrasive particles can do to the precision internals of an engine? It is evident, you have gotten bad education at the dealership, where whiz wheels are still being indiscriminately used daily!!
All these ranting is about lacking knowledge and wise enough to accept being wrong.
Aloha!!
I WILL POST THIS ONCE MORE IN CASE YOU DID NOT READ IT THE FIRST 6 TIMES.... I AM NOT POSTING TO SHOW YOU THE "PROPER WAY" TO REMOVE GASKET MATERIAL FROM THE DECK OF AN LS2. I WAS AND STILL AM POSTING TO ASK WHAT TO DO WHEN THE SOLVENT AND SCRAPER ARE NOT ENOUGH?
I will call you UNCLE if you are able to finally answer that question! But likely, the post above will be your last response...... Because clearly even though you know what not to do; you don't have a clue as to what to do.
DG
You don't know me and certainly have no idea of what I know!!
I certainly know that you don't know what you are doing! Right now, I simply enjoy watching you stuck at that limited knowledge level, frustrated even with the very basic!
Another thing - what I have forgotten is certainly more than what you know!!
Now is final!!
From the Farlex Free Dictionary:
ad·vice (
d-v
s
)n.1. Opinion about what could or should be done about a situation or problem; counsel.
2. Information communicated; news. Often used in the plural: advices from an ambassador.
From Collins English Dictionary:
advice (ədˈvaɪs
) noun
- recommendation as to appropriate choice of action; counsel
- sometimes plural formal notification of facts, esp when communicated from a distance
What you are "offering" is not advice, it's criticism. When you actually give us your top secret methods to cleaning, whether we agree or not, then we'll call it advice.
Thank you for once again avoiding the question and not providing the answer I have asked you for repeatedly.
Now its time for us to part ways; I may not have your superior level of experience when it comes to engine building, however I am intelligent enough to know when I am beating a dead horse. I will ask you politely not to post in ANY of my threads again, and I will be sure to avoid anything you create as well.
DG
Thanks,
DG
There is no perfect way to clean the decks in chassis on an aluminum block, but in my experience, the best way is to use a very very sharp gasket scraper and carefully remove the old gasket material. You can follow that up with a fine scotch brite pad by hand, and just be careful like was said to try to keep the fibers from ending up in the motor. I finish up with a stone and swipe the surface to remove any high spots.
Thanks,
DG
https://ls1tech.com/forums/generatio...ressure-2.html
DG
I was wrong as it seems as though Scotch brite does the same thing.DG
