99 Z28 Mass Air Flow Sensor Question
Old Sep 16, 2012 | 10:06 AM
mezzyshreder's Avatar
Default 99 Z28 Mass Air Flow Sensor Question
Hey Guys,
Just a quick question for anyone who actually owns or has owned an LS1. Please don't comment if you think you know. Only comment if you are sure you know from personal experience. I have a Granelli Motorsports Mass Air Flow sensor that I'm about to install on my 99 Z28 which is stock. Will this cause a check engine light resulting in me having to perform a computer tune? Or am I able to just make the swap with no real issues?
Old Sep 16, 2012 | 07:36 PM
litle88's Avatar
1st I know for sure your in the wrong section. Try the gen 3 external section.
2nd I also know that that MAF sensor is garbage and if you want to upgrade get a stock ac delco 85mm mafs. Just my .2
Old Sep 16, 2012 | 09:27 PM
Thanks for the info. Well taken.
Old Sep 17, 2012 | 02:16 AM
bww3588's Avatar
That maf is no better than the slp maf. A .35 cent resistor soldered into the maf wise and they charge you double what the original maf is worth.
These maf's are on the same playing field as the hand held tunes.
Old Sep 17, 2012 | 03:50 AM
So does that mean ill make better power with stock ?
Old Sep 17, 2012 | 04:02 AM
bww3588's Avatar
Yes only because trying to tune a bastardized maf like that is a pain in the ***.
Old Sep 18, 2012 | 05:01 AM
How can I get email alerts when following a thread? Currently, I must type in the search box to find this thread and others in order to view responses? Any help would be greatly appreciated.
