Who's running an LS2+Boost?
Old Sep 18, 2012 | 03:43 PM
Fastdriver1992's Avatar
Default Who's running an LS2+Boost?
currently have a SBC with a procharger (approx 700fwhp), its been running strong for about 7 years now and i know its going to go soon. anyway i want to build an LS and keep the Procharger and make (approx 800fwhp)so i have a few questions...
How much power can i make before i have to worry about the block?
its a DRAG RACE ONLY car so how many seasons have u guys run with that much power?
i want to save the weight and use an LS2 but should i go with an LQ for the strength?
how much boost can i run? (looking to run 15lbs)
Thanks
Anthony
Old Sep 18, 2012 | 03:53 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
We have been able to make over 1000rwhp a few times on the LS2 aluminum blocks. I would say where we start to worry would be right around 1200-1300 hp at the flyhweel mark. The type of power you are talking about should not be a problem, as long as you get some forged parts in the rotating assembly. As long as you have a good tune I would expect the motor to last for a pretty long time on 15 lbs.
Old Sep 18, 2012 | 04:40 PM
Thank you for your Expertise it was very reassuring, yeh it would be a stock crank with compstar rods, and Diamond/Wiseco pistons, and going to be an E85 "Blowthough Carb" setup.
Old Sep 19, 2012 | 10:21 AM
We are big fans of Wiseco pistons here, they are a great quality pistons with a great quality ring set for not a ton of money. Looks like you should be in a good spot!
