Warhawk 454
Old Sep 21, 2012 | 10:41 PM
josh2002-ws6's Avatar
Default Warhawk 454
I just got offered a killer deal on a tall deck Warhawk block with all of the need brand new forged internals to make the motor into a 454 nitrous motor. The block is the 9.8" tall deck and comes with a Callies 4.250" crank, Callies 6.460" H-beam rods, and custom 4.125" Diamond nitrous pistons. The guy is throwing in all of the needed bearings, head gaskets, and head studs. Do you think this combo will hold up to a 700 HP shot of nitrous? I know the internals will take it, but not sure on the block. I have never really seen to much on the Warhawk block.
Old Sep 21, 2012 | 11:17 PM
helicoil's Avatar
Read here: (World Record LS 1/4 mile e.t.)
https://ls1tech.com/forums/forced-in...12-update.html
And here: (World Record Drag Radial 1/4 mile e.t.)
http://forum.lsxtv.com/lsx-xtreme-up...paul-1257.html
Should answer your questions. Lol
Old Sep 22, 2012 | 08:51 AM
87silverbullet's Avatar
I don't think the block will be the problem. Sealing the heads to the block will be the problem. I hope you will be able to clamp it down well enough with all six bolts and a good gasket.
Old Sep 22, 2012 | 10:39 AM
If I get this short block I am looking at, I will be getting the All Pro LSW-1 285 heads. They are 6 bolt heads and they guy is including 2 sets of .053 Felpro MLS head gaskets. Do you think with the ARP pro series head studs he is including that it will seal pretty well? I am looking at doing the 69cc combustion chambers on the heads. With that size and the 5cc dome on the pistons I will be right at 13.25:1 on the compression ratio. I will top it off with a MAST LS7 single plane 4500 manifold and some type of 4500 single plane throttle body.
Old Sep 22, 2012 | 10:44 AM
427 zeo6's Avatar
Why not go with the All Pro intake it looks like the MAST? Price is way cheaper
Old Sep 22, 2012 | 11:11 AM
The guy I am buying the short block from already has a MAST manifold with 2 stages of direct port plumbed in. I am toying with also getting that. If I get a new intake I will be getting a All Pro tho.
Old Sep 22, 2012 | 01:51 PM
If you are going to go with the LSW 12 why not the 12-2's? They have a 1" thick deck and you have the cubes for it.
Old Sep 22, 2012 | 02:56 PM
I am looking into those also. I have an email sent out to All Pro asking them for a suggestion on heads and for prices.
Old Sep 22, 2012 | 04:01 PM
fuel's Avatar
callies h beam are good for 1000 hp....a 700 shot would spilt those rods at the seam
Old Sep 22, 2012 | 04:08 PM
These are the ultra rods, they are good to 1500 HP.
Old Sep 23, 2012 | 05:57 AM
BigRich954RR's Avatar
Warhawk block is good to Go for crazy power
Old Sep 23, 2012 | 09:07 AM
Well I made the leap and told the seller I will be buy all of the parts to build this motor. I can't wait now to get it in and start building when I get home from Saudi Arabia!!!
Old Sep 23, 2012 | 09:27 AM
fuel's Avatar
good....
Old Sep 23, 2012 | 12:40 PM
djfury05's Avatar
What kinda deal are you getting if you don't mind?
Old Sep 24, 2012 | 03:33 PM
lt1773's Avatar
i would like to know if Warhawk Block is woth it or not ?
Old Sep 24, 2012 | 11:50 PM
A great deal, lol.
Everything I am reading and looking at makes me believe that they are solid blocks.
Old Sep 25, 2012 | 08:58 AM
Sales@Tick's Avatar
Can't wait to do the valve-train for this bad boy it's going to be NASTY!
Old Sep 25, 2012 | 09:23 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Keep us posted!! That's going to be a torque monster
Old Sep 25, 2012 | 11:13 PM
CAMSTER's Avatar
I like to encourage you to ask around if you go with that compression and that much nitrous, the guys making big power are running 6 bolts heads with 3/8 inch 5th and 6th bolts and o rings on both block and heads, with copper head gaskets, just in case you'll need it, get it from the get go, save some money and lots of work and headaches. glwyb.
Old Sep 26, 2012 | 01:31 PM
Sales@Tick's Avatar
Not when you're turning 9000rpm
