VVT tuning with compcams limiter
Here @6300rpm you have a 6% swing in airflow and less than 0.5% change in HP. I wonder what's going on there?
I assume you logged these runs. Did you see anything interesting in the data that might explain the above? Also did you confirm the cam timing was remaining static when you locked it at +2 and +4?
