VVT tuning with compcams limiter
Old 01-04-2013, 05:24 PM
  #101
Area47's Avatar
Originally Posted by cam
Yeah Id like to try a different cam too but I have WAY too many projects piling up so this ones done for a few years. It cooks dont get me wrong I like it, but I could handle a hella lot more aggressive cam than this thing.
sadly enough, i think im running the smallest vvt cam in this particular group. id jump to the vvt-2, but would need set of heads to go with it
Old 01-04-2013, 05:56 PM
  #102
ringram's Avatar
Originally Posted by -TheBandit-
@3000 rpm I find it interesting that the airflow is only about 2% different between the +2 and +5 timing, but the torque is up by over 5%. I wonder what's going on there. Also look at this:
Here @6300rpm you have a 6% swing in airflow and less than 0.5% change in HP. I wonder what's going on there?
I assume you logged these runs. Did you see anything interesting in the data that might explain the above? Also did you confirm the cam timing was remaining static when you locked it at +2 and +4?
Its all about trapped air, aka airmass.
Old 01-07-2013, 12:30 PM
  #103
Area47's Avatar
who's runnin the vvt-2 cam?
Quick Reply: VVT tuning with compcams limiter
