ly6 exhaust valves in 317 heads
I bought a set of ly6 exhaust valves to put in my 317 heads because they're inconel severe duty and this is going to be a turbo motor. I swore they were 1.55" but apparently I was wrong and they are 1.59". Can I still just install them or do I have to have the heads machined for bigger valves?
Would be much less expensive to have the valves cut down, given the height and stem diameter are gonna work for you.
LS1Tech Premium Sponsor
The factory exhaust valve seat will take 1.59" without problems. Just ensure your machine shops cuts the seat, blends the bowl accordingly, and unshrouds the chamber if needed.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks for the info Matt. Any idea how much the work costs on average? I have a good machine shop locally, want to make sure im not getting hosed when I call for a price.
Basically will be the cost of a valve job and minor hand porting. Few hundred bucks should cover it.
__________________
