cam help
Old Dec 12, 2012 | 01:21 AM
lowrolr's Avatar
Default cam help
Im building a ls1 stock bore 3.989 with 243 heads and flat tops pistons. This will be in a second gen blazer. Trans is 4l60e with around 3600 stal higher if needed. And either 3.42 or 3.73 gears. I am looking for camshafter. Truck wont bbe driven a whole lot. But be capable if need be. Looking for most as possible just like anyone else. Will see some strip time but want to be able to drive there. No trailors for me. Thanks for help
Old Dec 12, 2012 | 08:57 AM
Tainted's Avatar
228R from texas speed
Old Dec 13, 2012 | 02:34 AM
lowrolr's Avatar
I was thinking about the texas speed torque v2. With 112+4 lsa. I know i may need to syep up to a 4.10 gear and thats not a problem. What is your opion on that setup. Hoping for 400 plus rwhp
Old Dec 13, 2012 | 10:06 AM
Tainted's Avatar
when lift is more than .630 stock rocker geomtry deminishes, something to keep in mind as I think the tq v2 is right at that lift
Old Dec 13, 2012 | 10:08 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The TorquerV2 is .595"/.598" lift with a 1.7:1 rocker ratio.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 13, 2012 | 10:09 AM
Tainted's Avatar
then you should be good its the tq v3 with the big lift im thinking of
Old Dec 13, 2012 | 06:08 PM
lowrolr's Avatar
Thanks guys
