5.3 crank swap question 12552216
I recently picked up a 07 5.3, so far the seller has lied about everything about it. Thats another entire thread...
My question here goes out to guys knowledgeable about swapping cranks. The crank is messed up as result of someone removing the #1 rod cap and then installing it backwards. Needless to say the crank (and 2 rods) are junk.
I want to know which cranks if any will go back into this (07) 5.3 engine? I am building this project to do some "stock" shortblock racing, so I can't go aftermarket or even do a rebalance nor do I want the cost. So I need a drop in.
Thanks. I have searched a few past threads here, and It appears that many engines use the 12552216 casting but some people are saying that the balance will be different.
