Livernois Motorsports LS Bronze Lifter Bushing Install Demonstration
In this video, Livernois Motorsports is installing bronze lifter bushings into a GM LS-Series block. Bronze Lifter Bushings are an option for any Livernois Motorsports build or customer supplied LS block.
This allows the use of keyway style or non-keyway style lifter bushings.
Numerous lifter bore sizes are supported with varying bushings available.
The entire procedure is done in-house on the CNC.
-Rick
-Rick
I've done that to every race engine I've built. That way if a lifter breaks or something happens, you don't usually damage the block. Just put in a new sleeve and go.
