Procomp head mini review.
Frank
Cam Motions designed me a custom grind that is 612 and 595 with a 226 230 on a 112.
Hey where is a good place to order head gaskets?
So far so good. The heads worked out real well.
I also ported the intake to match the heads. That worked out real well too. The new heads had ports much bigger than the stock heads and it just didn't make any sense to not open up the intake to match them. While I was at it I painted the intake to match the car.
There were a few other mods too.
Phadt racing headers with 4 into 2 into 1 design, and a wide band sensor.
Dumps from Badlandz.
I figured nothing is quieter than the factory mufflers and nothing flows better than open exhaust. Talk about mild to wild...
Vararam air cleaner too.
Still looks stock on the outside.
And a new torque converter from FTI.
Now for more data logging and tune file changes to get it all tweaked out.
After four data logs and new tune files it is really starting to sing now and it is making some decent power.
So I must say that the heads turned out real well, and so far I am very pleased with them.
http://www.youtube.com/watch?v=TJ2Mz...ature=youtu.be
