cam bearings clearance?
Old Jan 4, 2013 | 06:46 PM
bugy's Avatar
Question cam bearings clearance?
in high perfomance engines, what would be the proper or safe cam bearing clearance?
Old Jan 4, 2013 | 09:44 PM
bww3588's Avatar
I usually set mine around .003.
Old Jan 5, 2013 | 07:13 AM
RezinTexas's Avatar
0.002 - 0.003" is recommended according to the sources I've seen. Up to 0.006" is acceptable.
Old Jan 5, 2013 | 08:05 AM
td1168's Avatar
Don't mean to hijack the thread but how do you go about setting the cam bearing clearances? I'm only asking because I'd like to know for future work. I always thought the bearings were installed and if the cam turned freely you were good to go.
Old Jan 5, 2013 | 08:32 AM
KCS's Avatar
KCS
Moderator
You have the cam journals ground. I had mine done at a local crank grinder.
Old Jan 5, 2013 | 10:56 AM
bugy's Avatar
found one of them with .0021" so i was thinking i would need some more clearance...
Old Jan 5, 2013 | 05:48 PM
RezinTexas's Avatar
you can use some 600 grit sandpaper to open up the clearance as needed.
edit - this is for the bearing, not the journal. in case there was any confusion.
