Learning from experience
Old Jan 7, 2013 | 12:23 AM
  #41
lemons12's Avatar
Ls3 heads were originally designed for the 427 C6Z, were they not?
I am running them on my 370.. I expect it to make good power from the results I have seen.
Old Jan 7, 2013 | 02:07 AM
  #42
bww3588's Avatar
Idk if that was the plan, but they are obviously a variant of some sort.
I have a pair going on my 370 as well. Thru a stock ls3 intake and a 9 inch, I'm hoping for 475rwhp, but I'd be happy with 450.
Old Jan 7, 2013 | 02:10 AM
  #43
lemons12's Avatar
Stock ls3 intake here as well.. Built 60e with big converter and stock ten bolt with 373s. 475rw will make me very happy, expecting 465, anything less will disappoint.
Old Jan 7, 2013 | 02:19 AM
  #44
bww3588's Avatar
I'm just not getting my hopes up for disappointment. In the back of my mind, I'd be upset if I didn't see 475, but I've been down the road of hopes and dreams before.
Old Jan 7, 2013 | 02:28 AM
  #45
lemons12's Avatar
I hear you on that.. If i don't hit it, ill just waste some more money in this bottomless pit for the goal ill never reach... And love every minute of it! Lmao
Old Jan 7, 2013 | 03:25 AM
  #46
bww3588's Avatar
Couldn't agree more.
Old Jan 7, 2013 | 06:43 AM
  #47
96capricemgr's Avatar
Originally Posted by bww3588
https://ls1tech.com/forums/showthrea...2#post16984292
Less cubes, less compression and less supporting mods. Making a little over less than 10 HP than your setup. And the cam is designed to peak around 6k. Which it does. And this was done on a true 4 inch bore.
Less displacement will delay the rpm at which a head chokes which will push the rpm range upward.
Old Jan 7, 2013 | 08:03 AM
  #48
TurboMonte100's Avatar
Lets not forget the OP stated he had problems at lower settings, this tells me there are tuning issues. For whatever reason.
I just can't see the small area of less then optimal valve shrouding playing much of a role here if any. Small engine or big engine which ever, at worst the top end HP might be down slightly. It will not keep an engine of these sizes with head flow numbers as these from reving, 500+ ci maybe.
Old Jan 7, 2013 | 11:35 AM
  #49
redtan's Avatar
but apparently there is people on here that think they know everything and will not listen to anything someone else has to say
And you're not one of these people? Coming in here preaching like you know everything about the LS3 style heads and not listening to anyone else even though they have factual examples?
Old Jan 7, 2013 | 11:41 AM
  #50
bww3588's Avatar
That head should not be choking the engine.
Old Jan 7, 2013 | 01:47 PM
  #51
87silverbullet's Avatar
Lets not also forget that the OP changed to a cathedral head from a rect port head so, it might not be the heads but the intake itself since it had to be changed too.
Old Jan 7, 2013 | 02:38 PM
  #52
I thought this as well, when I first read it. I'm sure a number of things were changed along with some tuning. Not just a same day back to back comparision.
Old Jan 7, 2013 | 02:52 PM
  #53
newschool72's Avatar
Yea, it really could have been anything in the topend. For an example ,I changed 3 different cams in a 406SBC a few years ago because it wouldnt rev beyond 5K. It wound up being the sparkplugs! After the plug change, it would slam the 7K chip in the MSD and went from a 12.55 to an 11.30, 112mph to 120! Best 30 bucks I ever spent on a car.LOL
Old Jan 7, 2013 | 09:01 PM
  #54
Point was that if you scale rpm and displacement the example you posted was not so different and was not really any substantial meaningful argument for your opinion.
Old Jan 7, 2013 | 09:35 PM
  #55
bww3588's Avatar
It was actually. It doesn't change the fact the heads should not choke on the op's engine. And the fact that the example I posted is making roughly the same power as the op's engine is making the point that something else is wrong with his combination.
Whether it be a cam mismatched to the heads or something as simple as incorrect length pushrods.
The argument at hand was the heads being too much for anything less than a 4.065 bore, which my example and many others have proven false.
Old Jan 10, 2013 | 03:36 PM
  #56
Capown's Avatar
And BOOM goes the Dynamite!!
By Brett Foote | 2026-06-04 05:00:17
