Well after doing more research on camshaft specs, i have received 5 different sets of numbers on cams. Dont want to list names, but what are you guys running on these setups. Really dont want to buy a cam that will not perform to peak potential as i see on here with these particular heads it is hard to find the perfect cam. As listed above it is a iron 408, 11.6-1 compression, caddie lifters, Diamond pistons, callies crank and rods, stock rockers with trunion upgrade, FAST LSXr intake, PTM 102 tb, 50# FAST injectors, car is a 02 T/A, M6, Full weight car, 3.89 gears through a 9 inch with spool with 25 inch tires. Car is a street strip car, 1/8 mile, want to acheive peak horsepower without surge in the lower rpm. Plan to stage around 2500 and shift around 6800.
