What CP pistons do I need?
Old Feb 18, 2013 | 12:11 PM
Don Nguyen's Avatar
Default What CP pistons do I need?
Going to be boring/honing out my block to either 4.020" or 4.030" bore. Trying to look on the CP piston website for what I need and their site isn't very user friendly in the sense that's it's easy to search for what I need for my application.
Stock LS2 everything minus the bore of the block. I want valve reliefs in the pistons, which seems like all of their pistons come with anyways. Does anyone know what part number I need?
thanks.
-Don
Old Feb 18, 2013 | 12:57 PM
Tainted's Avatar
All of it depends on your setup. Too large of a relief and youre gonna lose compression. Not enough relief and your valves will hit.
Old Feb 18, 2013 | 01:05 PM
Don Nguyen's Avatar
I don't think you can select valve relief, so that's not as much of an issue as far as figuring out which piston I need from them.
-Don
Old Feb 18, 2013 | 01:23 PM
Tainted's Avatar
You should be able to, there are all different ones from -10cc - +10cc and beyond and everything inbetween.
Then youve got domed, dished, flat etc
Old Feb 18, 2013 | 01:26 PM
redtan's Avatar
Might want to get that blocked checked out if you want to take it 0.020 or 0.030 over.
Old Feb 19, 2013 | 10:43 AM
djfury05's Avatar
Are you building the motor for boost or NA?
Old Feb 19, 2013 | 10:45 AM
Don Nguyen's Avatar
I am building it for NA.
Old Feb 19, 2013 | 11:42 AM
Tainted's Avatar
Don, why dont you PM me with your entire build youre planning and I'll try to help you out, or at least get you going in the right direction.
Old Feb 19, 2013 | 04:43 PM
LS1MCSS's Avatar
CP doesn't have anything listed on their site, like you need. They do have a low compression piston or some with a larger bore.
Old Feb 19, 2013 | 05:33 PM
KCS's Avatar
KCS
Moderator
Why CP? Why not Wiseco?
