Compacted graphite Iron Cylinder block
I heard about this engine in one of my diesel classes and was wondering if this engine exists for gas engines as well it's said to be 70% lighter than cast iron blocks 200% the fatigue limit and 40% more rigid than cast iron I'm hoping to use this to provide an engine that can endure the stress of high HP, high torque, and high temperatures and remain reliable I also plan on adopting another diesel trait by installing sleeves for block protection as well as making overhauls much easier in the future hope to hear from anyone who can help me out.
Thanks Tim I just did a little research on it and apparently it's widely used in toyota, bmw, GM, Rolls Royce as well as audi I searched it before a while back but all I was getting were diesel applications so the future is looking a little brighter for my build thanks for the help now the only thing between me and that engine should be is a price tag
As stated in my name I am truly a 4thgenrookie and live up to that moniker, and I'm not very knowledgeable or experienced with these engines this will be my first project, but looking at the evidence 70% lighter 200% the fatigue and 40% more rigid it sounded like a sure fire winner if you could give me a little info on the engines your referring to you might be able to sway me but I just want to make the most durable or reliable engine possible able to withstand a beating and still fire up and run like a champ
the blocks I mentioned have stood the test of time, theres a lot of people running them and pushing ridiculous HP both NA and FI, and are readily available.
I've just never seen the things you mentioned for LSx
Thanks all of you, I was just concerned about warpage, cracking stuff like that you hear a lot about esp. in aluminum blocks will do more research on some of the engines you guys mentioned but yeah I was wondering about the bottom end products as well If anyone could refer some good manufacturers they've had experience with
Callies is certainly one of the better forged rotating assemblies.
Heres some food for though on aluminum blocks and some quick info
Theres plenty of people on here running 800+ hp on aluminum blocks. A few key mods can make them very stout, and if the aluminum isnt good enough, the iron varients should be. If you are goimg for big hp, large bore then either sleeving a block or going to the aftermarket blocks are your mext option.
Having said all that, if youre budget conscience, then the l92/ls3 block is a great one to look into. You get the bigger 4.060 bore, improved casting quality, and longer sleeves vs previois blocks.
I still haven't heard a price range Dart seems to be the only manufacturer to actually say they have them... it almost seems like a secret lol, GM is hoarding them for the zombie apocalypse, and your probably right, but hey.. hopefully your wrong.. about the new ones at least lol... btw where did you find the info?
