R07 CGI block
Old Feb 24, 2013 | 04:10 AM
4thgenRookie's Avatar
Post R07 CGI block
Are they attainable by the average joe, has anyone ever seen one of these on the street, know where to find one, price range, etc. Any information in the right direction is appreciated
Old Feb 24, 2013 | 08:54 AM
Tainted's Avatar
I have never heard of it on here. What is it exactly? Theres already some serious aftermarket blocks available
Old Feb 24, 2013 | 09:24 AM
SWeiser31's Avatar
Ebay has a bunch of used parts for that, but I didn't see any blocks.
Old Feb 24, 2013 | 09:36 AM
bww3588's Avatar
NASCAR engine. Similar deriviative of the ls.
Old Feb 24, 2013 | 05:35 PM
It is an Compacted Graphite Iron block said to be 70% lighter than grey cast iron 200% the fatigue limit as well as 40% more rigid than cast iron I too had not heard of it until 1 day in my Diesel class and it sounded like a good prospect for a build on a gas engine then I did a little research and found Nascar was way ahead of me and they've been using it for quite some time GM I believe caught on after Toyota introduced it and made their own version in 2007 called the R07 but I have not been able to find any info on buying an actual block only intakes, cyl. heads, and distributors
Old Feb 25, 2013 | 07:30 AM
96 Comp T/A's Avatar
It has absolutely nothing in common with an LS engine. Not even close. It is a purpose built race engine platform.
If you want CGI, DART will cast blocks in CGI, maybe one of their LSNext blocks in CGI is an option.
Old Feb 25, 2013 | 01:39 PM
flash911's Avatar
Correct. I checked with them and it will be available after they get their cast iron tooling/production up and running. The LS Next CGI block will have strength but no weight advantage...
Old Feb 25, 2013 | 03:22 PM
I'm Kind of bitter, I mainly wanted the block in the first place for it's combination of perks now it seems to be just another block however it still isn't that bad for the price range just when you think you have an edge on everyone else... I thought this would surely turn my car into the mach 5 lol
Old Feb 25, 2013 | 03:41 PM
Tainted's Avatar
I think unless youre making north of 800hp the aluminum blocks are fine (with the exception of serious FI or nitrous cars), and even then the iron varients are very stout. and if that isnt enough theres already enough blocks on the market
Old Feb 25, 2013 | 04:31 PM
Guess I'll stop being stubborn, I want to make a street/strip car you guys have more experience with this I'm all ears, I want something scary that shakes when you start it. where do I start?
Old Feb 25, 2013 | 04:47 PM
The weight advantage usually comes in after they chuck the CGI block up in the CNC center and go over every square inch with a carbide bit. CGI lets them take more meat away and still maintain structural integrity.
Old Feb 25, 2013 | 04:56 PM
Big cubes and big camshaft will get you going in the direction you want to go. It all comes down to budget and goals. Lots of $400 truck blocks have been in the 9s and even a few faster than that.
Old Feb 25, 2013 | 05:06 PM
For a 93 3.4l camaro will a 383 or 396 do?
Old Feb 25, 2013 | 07:38 PM
mkvamso's Avatar
you can buy them from race teams occasionally
ive seen used short blocks for around 10k iirc
id say an lq4 or lq9 block would be fine for just about any street/strip build
Old Feb 25, 2013 | 07:39 PM
Tainted's Avatar
Heres an economical option for big cubes, big power, and probably the best $/reward payoff.
Get an aluminum 6.0 block, and have that sleeved to a 4.125 bore. The sleeving is normally about $2000-2500 depending, plus the cost of the block etc.
Forged rotating assembly (callies is nice) 4" stroke. This gives you a 427
LS7 top end
Fast intake
Custom cam
Obviously full supporting mods
Hello 600+rwhp
Old Feb 26, 2013 | 12:03 AM
LS7 top end
Fast intake
Custom cam
Hello 600+rwhp
I like where your going
Old Feb 26, 2013 | 12:06 AM
Appreciate all the input
Old Feb 26, 2013 | 06:31 AM
So would it be best to just go with an 6.0 aluminum block derived from the LS series if going with LS7 heads? And if so what block would best fit for the assembly of the application Tainted recommended earlier?
Old Feb 26, 2013 | 11:53 AM
redtan's Avatar
An ls2 block would work great with that setup.
Old Feb 26, 2013 | 12:02 PM
Tainted's Avatar
Yea you can use any of the aluminum ls blocks, the sleeve will determine the size of your new bore 6.0 blocks are plentiful and fairly cheap making them an easy target.
