lq4 Question
Old Feb 25, 2013 | 08:58 PM
Blown02Camaro's Avatar
Default lq4 Question
Eventually I will be building a stronger motor to handle more power than the 383 I have now. My question is, what all need to be done to the block to handle 1000+rwhp.
Old Feb 25, 2013 | 09:05 PM
Tainted's Avatar
Sleeve it, billet main caps, studs, girdle
Old Feb 25, 2013 | 09:08 PM
JUSTINSWS6's Avatar
arp rod bolts, arp head studs, arp main cap bolts, and forged internals. It should hold fine
Old Feb 25, 2013 | 09:16 PM
My bad guys I failed to mention i was going to use an iron block not the aluminum block
Old Feb 25, 2013 | 09:19 PM
Tainted's Avatar
Same deal. Sleeve it, main caps, studs, girdle if it will fit
Old Feb 26, 2013 | 08:11 AM
Correct me if i'm wrong, but I didn't think you needed to sleeve an iron block
Old Feb 26, 2013 | 08:29 AM
Tainted's Avatar
You can, it will be stronger then as well and have the large bore. You can only bore these lsx motors so much, especially the aluminum ones.
Old Feb 27, 2013 | 11:51 AM
OK, But most people I see that build the iron blocks do not sleeve them because they already can withstand a beating seems like a lot of extra work and money for the same result to me.. I know you do need to change the sleeves on some of the aluminum blocks of you plan to make a lot of power
Old Feb 27, 2013 | 12:02 PM
Tainted's Avatar
Its gonna boil down to what you want to do and how much power. If you want the big bore you have no choice but sleeve it, buy an aftermarket block or get an ls7 block.
Old Feb 27, 2013 | 05:00 PM
BUt if I don't a big bore motor then there is no reason to sleeve the iron block am I not correct?
Old Feb 27, 2013 | 05:09 PM
Tainted's Avatar
Correct.
Old Feb 28, 2013 | 02:09 AM
bww3588's Avatar
I think more information is needed to make an accurate answer.
How do you plan to make this power? Na, you're going to need a lot of expensive parts, and more cubes than a stock iron block can handle and still be reliable.
If you're going with boost or spray, you can get it done with the iron block, forged internals and studs all the way around.
Old Feb 28, 2013 | 09:14 PM
I'm going with a turbo and c16
Old Feb 28, 2013 | 09:22 PM
Tainted's Avatar
Heres my recommendation. The newer the block the better, the casting process got better along the way. Next have it sonic checked and a good going over. Still think about sleeving it thougb, but if you go that route get an aluminum ls3. More cubes, better block, longer sleeves
Again, studs, main caps, forged assembly, good bearings rings etc, if you can run a girdle support go for it, it wont hurt.
