What is the Max bore/stroke for a LQ4?
Any input would be appreciated.
It will net you a 390 cube motor this is the motor AES racing makes in their 390 setup.
http://aesracing.net/product_info_390LS1.htm
On a high strung N/A application sure you might see a bit more torque in a 408 vs. 364, but with all that insta-boost from the twin screw you won't miss the extra torque down low that a bigger cube motor might make.
Like silverbullet said before, a 390 is probably your best bet if you really care about the cubes. Although depending on how much boost you plan on pushing though this you might even be better off with a smaller setup like a 366-370.
I was not familure with the AES option. Great info I'll give it a long hard look.
Thanks.
It's not the size of the boat or the motion of the ocean...but whether or not the captain can stay in port long enough for the passenger to get off".
Now back to our regularly scheduled programming....
