Building an LS2 402...(RUNNING with Video)
Don't do the trap door IMO My roller has it and it looks cheap as ****, dropping the tank is not as bad as people make it seem . . . just make sure to do it when it's empty or close to it lol
Dropping the tank is very simple, remove panhardbar, exhaust will need to be removed and then drop down the tank. I'd rather do that every-time instead of cutting up the body. Just my opinion
The car is all the way back together except for my fuel rails. I am embarrassed to admit that I was cheap and bought a set of the Professional Products rails and they leaked like hell. So, my FAST rails will be in today. May get some video of the car running tonight. I am working on a base tune to get the thing to idle. It has been ran for maybe a total of 30-45 minutes, and has been all the way up to temp.
I primed the oil pump before starting it by pulling the fuel pump relay and cranking it for about 15 seconds at a time, after the third time the oil pressure came up to 40 PSI while cranking. Oil pressure shoots up to about 70 PSI when I rev it, only revved to about 3K. It sounds pretty healthy...
I hope to be putting the thing back down on the ground tonight. I had to drop the K member down about 3/4" to get my hands over the intake so that I could get the rails in and out. Its very tight.
The car is very dirty....lol needs a bath.
Oil pressure is really good!
I need to do a lot of tuning still, also have the dreaded LS7 lifter noise....they are loud, not real sure what to do about that yet.
I am also not sure about if the fuel pressure is supposed to bleed off with the key off. It seemed like when I first primed the system it was holding pressure around 45 ps key offi, 60 psi running. Now it still holds 60 psi running, but slowly bleeds down when you shut it off. It takes it maybe a minute to go to zero. I do not smeel gas at all nor do I see a leak anywhere. If anyone has a gauge on thier car please chime in.
