Small Cam LS3 build in a 4th gen
Old Mar 16, 2013 | 02:21 PM
blackLS1m6's Avatar
Default Small Cam LS3 build in a 4th gen
I have a stock LS3 that im getting ready to swap into my 2000 WS6. Mods are a 3600 vigilante, hooker long tubes and a lid. Its my daily driver so reliability and excellent street manners are a must. Thinking about going with the crane cams 1449551 210/218@0.50 .551" lift, I also have a new comp 224/228@0.50 on a 112 lsa that i could use. Ive done plenty of searching and im curious if anybody has done a similar build.
Old Mar 16, 2013 | 03:24 PM
leeluther252's Avatar
If you are looking for something on the small side with big gains go with the tsp 225/230 .617"/612 It has great manners and picks up about 60+
Old Mar 16, 2013 | 03:48 PM
batboy's Avatar
The 224/228 cam is fairly small even in a LS1. The other cam you mentioned would be tiny and not even worth it. I say sell 'em both and have Tick Performance fix you up with a better one.
Old Mar 16, 2013 | 08:58 PM
Dyno Junkie's Avatar
Red face
I'm using a Comp Cam in our 3,880lb Monaro.
231 239 .617 .624 113.
Old Mar 17, 2013 | 08:18 AM
Blackpanther99's Avatar
I agree with this^ You can get a bigger spec'd cam and still have that drivability that you want
Contact Martin @ Tick performance.
Old Mar 17, 2013 | 04:03 PM
Sales@Tick's Avatar
Our Stage 1 LS3 Street Heat cam has been used with stock torque converters in 5th gens successfully with no issues. How's that for mild mannered!
It is 227/236 .61x"/.57x" 114+4 and has a great torque curve as well and is far from a peaky camshaft. It would be an ideal daily driver cam as it has only 4 degrees of overlap making for a smooth ride while still having a nice lope at idle!
Old Mar 18, 2013 | 05:23 PM
Sales@Tick's Avatar
Street Heat Stage 1 for LS3 idle clip:
Old Mar 18, 2013 | 06:11 PM
low2001gmc's Avatar
MASS seller approved
x3....
Old Mar 18, 2013 | 06:12 PM
low2001gmc's Avatar
sounds like a plan there Martin....keep up the great work....
Old Mar 19, 2013 | 07:17 AM
Sales@Tick's Avatar
Thanks!
Old Mar 19, 2013 | 11:10 AM
VTC_WS6's Avatar
Personally, I'd stay as far away from Martin @ Tick as you can...
....he makes me spend $$ lol!
<-- Tick LS3 Polluter on the way!
Old Mar 19, 2013 | 02:01 PM
LOL^ You just cant get enough parts cant you? Nothing but good things about Martin's cams.
Old Mar 19, 2013 | 05:08 PM
Sales@Tick's Avatar
Originally Posted by vtc_ws6
personally, i'd stay as far away from martin @ tick as you can...
<-- tick ls3 polluter on the way!
lmao!!!
Old Mar 19, 2013 | 07:56 PM
JIMB's Avatar
I have the TSP 225 in my LS3 Camaro. Runs great and no problem with power brakes. It's a stick. Did 420 at the rear wheels with crappy 3/4 length headers.
Old Mar 19, 2013 | 08:34 PM
badazz81z28's Avatar
Its a waste of an LS3 in a 4th gen if your not going to put a strong cam it it...
How does it feel to know my LS1 puts more to wheels than you do ^^^
If it doesnt require a converter, you went too small
Old Mar 19, 2013 | 09:19 PM
S10xGN's Avatar
Ummm, not everyone wants to run 9's in their DD. Maybe the OP prefers reliability over that last 1/2 HP advantage...
Old Mar 19, 2013 | 09:22 PM
Lol...Buy a Honda. You can still put in a healthy cam and still have the drive-ability and reliability. I guess I just really suggest he doesn't go too small.
Old Mar 19, 2013 | 09:38 PM
blackLS1m6's Avatar
Very impressive dyno junkie! Low 11s in a heavy car! Thanks for the input, not sure i want to go that big though.
Thanks Martin! A strong torque curve and complete drivability is what im after. Just looking to keep it fun and reliable without having to check valve springs every 10k. The stage 1 sounds pretty nice! Id be willing to go a little bigger too. When i get my 70 stage 1 back together ill be contact with you!
Originally Posted by BODUKE
I just completed a ls3 swap in my '02 Camaro. It has a eps 226/234 cam in it, what a difference from my previous set up! It has good street manners and hauls ***!
Thanks Boduke, exactly what i was looking to hear.
I hear you, but everything i own has a big cam so im looking to keep it well mannered without any nuisances.
Old Mar 20, 2013 | 10:01 AM
WKMCD's Avatar
Originally Posted by bozzhawg
Is there any advance ground in the cam ? 224/228 112
What is the ICL?
What lobes?
Lift???
Old Mar 20, 2013 | 08:24 PM
JIMB's Avatar
The TSP 225 cam is very driveable. Minimal tuning and the LS3 is in a 73 Camaro. I didn't buy it for the dyno numbers. I made my choice looking for a cam that will out perform the stock cam by a good margin. Have a bit of chop at idle, not much but a bit and still run down the road on a long trip at 22 mpg plus.
I've had the big and bigger cams in cars. They are kind of like a hardtail motorcycle . The hardtail gives you the total chopper expirence in about 20 miles. Same thing with a big cam.
Kind off the subject to the original OP.
