408 results!
Old Mar 18, 2013 | 08:24 AM
USMC5811's Avatar
Default 408 results!
Just had my 408 tuned over the weekend. 6.0 iron block, PRC Ported/polished LS3 heads, 235/242 .635/.615 112+2 LSA, LS3 Intake and she put down 475/475 with 100% humidity. hoping on a nicer day and removing my crappy ChokeMaster exhaust with an LM1 i'll get closer/break the 500HP mark!
I also had 444TQ coming off of idle which i was really impressed with!
Old Mar 18, 2013 | 10:06 AM
86Z28USAF's Avatar
Nice!!!!!
Old Mar 18, 2013 | 10:57 AM
Consultant0311's Avatar
Nice numbers. I'm putting together something similar.
Old Mar 18, 2013 | 11:27 AM
USMC5811's Avatar
like i said, hopefully i'll be able to break that 500 mark with some minor tweaks!
Old Mar 18, 2013 | 12:01 PM
jlrz28's Avatar
10 Second Fun Car
Congrats, any flow numbers on the heads?
Old Mar 18, 2013 | 12:15 PM
Jimbo1367's Avatar
How about brand of cam& lobes used.
Old Mar 18, 2013 | 01:10 PM
USMC5811's Avatar
Comp Cams EHI/LXL lobes. Cam was spec'd by Pat G. And ordered from TSP
http://texas-speed.com/p-1179-prc-ls...ted-heads.aspx
these are the heads that i got and they have a flow chart listed.
Old Mar 18, 2013 | 04:52 PM
Giddswat's Avatar
Nice numbers!!
Old Mar 24, 2013 | 07:09 PM
USMC5811's Avatar
Old Mar 25, 2013 | 07:42 AM
Higgs Boson's Avatar
that torque isn't "off idle." the chart is in run time rather than RPM....0 seconds represents 2800 RPMs....still nice numbers but you should try and get a print out with RPMs at the bottom.
Old Mar 25, 2013 | 08:10 AM
Roarin_8's Avatar
Looks like his RPMS are on the right side of the graph. Looks like 446 TQ is coming in at around 6200 rpms.
Old Mar 26, 2013 | 03:08 PM
fastvet's Avatar
I like the power curve. I don't mean to be that "guy," but aren't hp and tq numbers supposed to cross around the 5250 rpm range? It looks like it crosses at the 6300 range. Maybe I'm reading it wrong.
Old Mar 26, 2013 | 09:14 PM
Roarin_8's Avatar
It's just the way the graph is set up, would be better to have the rpms at the bottom. Top of the graph does say horsepower and torque vs time. Maybe the rpms on the right side of the graph are moot.
Actually, look at the green line (rpms) and follow where HP and Torque cross, it's right at 5250.
