Trunnion Bearings breaking in LS2 GTO
A month ago, when it started ticking and we found the first broken trunnion bearing, I had my builder check the springs and they were fine. We replaced the bearing and it was fine. The ticking went away and everything. Then, about a week ago, the ticking returned, so we took off the valve covers, and sure enough, 2 more bearings were broken. Has anyone seen or heard of this happening? We are going to go ahead and fix it, however, just replacing them isnt solving the root issue.
No one around here has heard of them going bad, much less 3 of them.
Any thoughts? Oiling problems? Lifters?
__________________
Also which springs do you have PRCs or Comp Cams?
Have you made any changes in the oil you're running ?
PRC .675" EHT Open Spring Pressure: 450 lb. @ .600" lift
I run the same cam except 111+3 lsa, and PAC 1521 dual springs.
PAC 1521 Open Spring Pressure: 372 lb. @ .600" lift.
http://lsxnation.net/forum/showthrea...-you-comp-cams
http://lsxnation.net/forum/showthrea...our-f-trunions
https://ls1tech.com/forums/generatio...eck-yours.html
Go CHE bushes, or leave them stock. Spread the gospel, avoid comp trunions like the plague. The only thing worse then those pieces of crap is the customer service you get when you try to get them to make it right.
Another shop had done the work, so I'm not sure if the Trunions were installed incorrectly or what. I'm not saying Comp made a poor product, but there are some who have no problems with them at all and some who do.
Last edited by autogeek23; Mar 19, 2013 at 11:39 AM. Reason: information has been updated in comments above
Most likely I will be upgrading to some roller rockers that are pre-assembled in the very near future, then.
