cam help
Old Mar 26, 2013 | 05:07 PM
ws6guy27's Avatar
Default cam help
Hey guys im going try give as much info as I can but I needing cam choice help. Probably going be cuatom grind cam.. and prolly not comp.. there not as strong as others and wear down faster. So cam going be in a ls3. 418..tfs 235.. 11.8cr. M6. 3.55 gears(prolly change to 4.10). Lookimg for hyd roller. Don't mind changing springs ar times. Would have to anyways. I do want a big cam. Going to be on street some maybe once or twice every two weeks.. but moatly see track.. doing lot of racing. Cqr is a 2000 ws6. I would like to see 570-580 at the wheels. And a good power range cam. Roughly from 2200-6800. Pulls hard once WOT. idk if this is possible.. im sure I forgetting stuff. But if I am just ask. I like find cam numbers soon
Old Mar 26, 2013 | 05:14 PM
Tainted's Avatar
Id have pat spec it and EPS grind the cam. EPS uses proprietary lobes that are easier on valvetrain and make better power.
Old Mar 26, 2013 | 05:18 PM
ws6guy27's Avatar
Yeah I heard of eps. Just couldnt think of abreviations exactly. And I should have pat g spec one out. Am I forgetting anyrhing.. I going with a 26" tire now.. idk if should go with 28 or not. With gear change and what not.. is it possible to run 9s? Lol with my set up
