What are the pros & cons of VVT
Old Apr 16, 2013 | 11:00 AM
jimmer1g's Avatar
Default What are the pros & cons of VVT
I posted this in another section of this forum and got no response I am trying to figure out if I should keep the VVT or get rid of it I plan on changing the cam in my LY6 so that would be the time to change it one way or another the motor will be going into a 63 Nova not a daily driver but a good running 400 to 500 horse car to drive on the weekend please help I'm new to this so I will be asking a lot of questions on here this is a great sight lots of info I have searched for this answer with no luck
Old Apr 16, 2013 | 05:28 PM
1989GTA's Avatar
400 to 500 crank horsepower would be no sweat with VVT retained in your LY6 motor. I would keep it. If you have DOD I would get rid of that.
Old Apr 16, 2013 | 06:04 PM
newschool72's Avatar
VVt is great in milder combos, like your goal. It is basically a variable cam sizing, based on rpm. Little cam down low and bigger at higher rpm. Broader torque and HP curves. Whats not to like?
It really retards and advances the cam, which is KINDA like small cam, big cam. Thought I better throw that in there before someone blew me out on it.LOL
Old Apr 16, 2013 | 08:31 PM
jimmer1g's Avatar
I didn't think the LY6 had DOD am I wrong
Old Apr 16, 2013 | 08:40 PM
1989GTA's Avatar
May not have it as most went into vans and such.
Old Apr 16, 2013 | 09:07 PM
jimmer1g's Avatar
How can you tell if it has it this motor came out of a 3500 van 2008
Old Apr 16, 2013 | 09:52 PM
KCS's Avatar
KCS
Moderator
If you go with a VVT cam, I'd strongly recommend doing some serious research to ensure you get the correct parts. There are two different cam cores and phasers since 2007. Mixing up the cores and phasers could change cam timing as much as 13 degrees!
Old Apr 16, 2013 | 10:43 PM
jimmer1g's Avatar
Thank everyone for replying lots of great info looks like I need to start doing my research on cam spec
Old Apr 19, 2013 | 08:41 PM
LongIsland63SS409's Avatar
Building a 2008 LY6 street/strip engine also. I am using the Texas Speed VVT 3 cam.
Texas Speed also emailed me the updated phaser tables which I am going to install with my HP Tuners programmer.
Mike
Old Apr 20, 2013 | 09:08 AM
KCS's Avatar
KCS
Moderator
Mike
Like I mentioned earlier, please make sure you have the correct part numbers. There are different phasers, phaser limiters, and cams for the VVT engines. The 2007-2008 VVT engines could have either of the two and unless you checked the phaser and informed TSP, you have a 50-50 chance of getting the correct parts.
If you look on your phaser gear, the last three digits of the part number are cast into it. This will tell you what cam core you need as well as what limiter kit. Below is a link to Comp Cams' tech bulletin describing the required part numbers.
http://www.compcams.com/Base/pdf/156...189%20core.pdf
Old Apr 26, 2013 | 01:38 PM
Area47's Avatar
for reference on finding the right cam core to go with your phaser.
http://www.performancetrucks.net/for...m-swap-504902/
Old Apr 29, 2013 | 01:30 PM
jimmer1g's Avatar
What is a good place to shop for a VVT cam with specs
Old Apr 29, 2013 | 02:41 PM
I purchased my cam VVT3 from Texas Speed since they furnished me with the updated phaser tables.
Mike
Old Apr 29, 2013 | 03:40 PM
1989GTA's Avatar
Mike
Same here. In my case I sent my E38 ecm off to TSP to get it reprogrammed as I wanted to change some other items as well.
Old Apr 29, 2013 | 09:41 PM
BigAce's Avatar
VVT itself is awesome. basically it broadens the power curve giving you a little more grunt down low and a little more top end than you would have with the same cam on a fixed timing set.
TSP told me that I should delete VVT when i told them I wanted to build a crazy stroked/blown/everything motor so i went with a 3 bolt cam.
On a milder build I would keep VVT.
I think it boils down to reliability and ease of tuning. VVT cam phaser is another moving part. VVT also may make it a bit more complicated to tune.
Old May 1, 2013 | 08:41 AM
jimmer1g's Avatar
I plan on doing a mild build I'm working on getting some pic together I will post them up this week
Old Jun 8, 2013 | 11:20 AM
Any pics/updates?
Mike
Old Jun 9, 2013 | 12:10 AM
Jimbo1367's Avatar
Default vghhhtyfgvźg
Do a SEARCH for Patrick G .
He can spec you a custom VVT cam for only $25 or $50.
Old Oct 6, 2024 | 01:02 AM
BlackHawk7695's Avatar
Default Ly6
The LY6 does have VVT but not AFM/DOD in the truck
Old Oct 6, 2024 | 01:15 AM
Your info is correct but 11 years too late.... Check post dates....
