Porting aftermarket heads
Old Aug 20, 2022 | 06:34 AM
SteveJewels's Avatar
Veteran: Navy
Default Porting aftermarket heads
The AFR site lists their 260 Mongoose heads as;
"AFR’s 260cc LS3 “Mongoose” heads feature 100% CNC ported intake, exhaust and chambers".
Why do they not cast the head with optimum dimensions instead of porting after they are cast?
Old Aug 20, 2022 | 09:48 AM
With any casting there are almost always minor imperfections.
Having said that, it is now proving that as-cast can flow just about as well as CNC porting if the basic port shape is a winner to start with.
Old Aug 20, 2022 | 09:59 AM
Darth_V8r's Avatar
Moderator
The tolerances on machining are far better than casting. You get far more consistent dimensions - I.e. less variability - piece to piece and even port to pet within the same piece.
Also, the texture left by tooling is beneficial to wet flow and atomization due to boundary layer effect.
Old Aug 20, 2022 | 10:11 AM
84ta406's Avatar
I was just going to say the same thing, on anything non DI surface finish makes a difference. How much difference is subjective but there is a reason people like Chad Speier uses a burr finish on some stuff..
Old Aug 20, 2022 | 06:25 PM
Darth_V8r's Avatar
Moderator
Yeah the stuff I've seen surprise people you'd never be able to sell because it looks like stir fried ***. But it flows like crazy. One day I'd like to get someone to finish my ports with a bent tool. Not kidding
Old Aug 20, 2022 | 08:21 PM
Corona's Avatar
another 1 of my Uncles. I said A Common sense statement on the subject.
https://www.yellowbullet.com/threads...#post-73766694
Old Aug 25, 2022 | 05:50 PM
Veteran: Navy
Appreciate the explanation. I have so much to learn.
I am looking at ported LSA for a build so this is very helpful.
Another question, what is "non DI surface finish"?
Thanks!
Old Aug 25, 2022 | 05:54 PM
1FastBrick's Avatar
Thanks!
It should read,
"on anything non DI, surface finish makes a difference."
The "DI" is referencing "Direct Injection"
Old Oct 4, 2024 | 07:30 PM
Mark O'Neal's Avatar
An engine is an air pump. The more air you ingest and expel, the more power you will make.
Boosted engine love large cylinder heads.
Old Oct 5, 2024 | 08:08 PM
wannafbody's Avatar
I think some people were experimenting with dimpled ports, like a golf ball.
Old Oct 6, 2024 | 05:05 AM
BCNUL8R's Avatar
I've had good success with smaller unported heads and running more boost pressure no issues with heat or anything and I get better throttle response off idle and lower rpms.
