The best camshaft for hp
Hi guys I have got lq4 engine and I bought :-
1-HOLLEY 102MM INTAKE MANIFOLD FOR LS3 HEADS
2-HOLLEY FUEL RAIL
3-BBK 102MM THROTTLE BODY
4-GM LS3 CYLINDER HEADS CNC PORTED (CFM)350
5-MANLEY PISTONS BORE 4.065 IN
6-COMP STAR CONNECTING RODS H-BEAM
7-HIGH FUEL PUMP PRESSURE
I JUST NEED AN ADVICE FROM SOME ONE HOW KNOW WHAT I TALKING ABOUT IT SOMEONE HAVE A GOOD EXPERIENCE AND TILL ME WHAT I CHOSE.
REMEMBER I DONT WONT TO RUN BOOST OR NITROUS.
I NEED A PERFECT HP
2-HOLLEY FUEL RAIL
I NEED A PERFECT HP
. on a setup like that I'd almost always recommend a custom grind. they're not much more than an over the shelf cam, but will perform better if spec'd by someone good. I'm not sure who the go to guys are for ls cams but i'm sure someone will chime in about that.
what in the FLYING BLUE **** did I just read?!?!?
Read the forum rules, learn how to search, and try using the English language.
Also, do me a favor and punch your mother in the mouth for spawning you.
Any vendors Donkey Dick v3...
Seriously, it looks like English is not your first language so allowances should be made. Look around for someone running that combination or close. That group gets pretty small with the LS3 heads and a carb intake but there are people who run that setup.
Good Luck!
Good Luck!
Damn, the one place that makes me feel like this is blue collar America and I read this. This sounds like a shitty Craigslist ad that nobody want's to buy your shitty car that you don't take care of.
