My Cam Kit
Old May 7, 2013 | 05:34 PM
409CISecondGen's Avatar
Default My Cam Kit
Update: Now a build thread.
400whp isn't cutting it, so I'm finally going to put a cam in my car.
EPS 234/236 .629"/.629" 113 LSA+4 spec'd by Pat G
BTR 3/8 7.425 Chomemoly Pushrods
Comp Cams Rocker Arm Trunion Upgrade
BTR .660 Dual Spring Kit with Titanium Retainers
TSP Ported LS6 Oil Pump with new O-ring
IWIS Timing Chain
TSP Basic Camshaft Bolt/Gasket kit
Powerbond 25% Underdrive Pulley with new belts
Overdrive Alternator Pulley
Injector Dynamics 1000cc
Deutsch Werks Fuel Pump
What am I missing that I still need to buy?
Old May 7, 2013 | 11:43 PM
Bump, lets hear some HP predictions.
400whp/400wtq now
-Vararam
-Ported TB
-Fast 102
-Kooks 1-3/4 to 1-7/8 Stepped Headers
-Catless
-Corsa exhaust
Old May 8, 2013 | 02:43 AM
stangcobra's Avatar
Old May 8, 2013 | 04:30 AM
Originally Posted by stangcobra
433/408
I would expect that without the FAST 102 on an off the shelf cam. I'm betting 445/420.
Old May 23, 2013 | 02:27 PM
This is now a build thread, the fuel system has arrived and the cam is being ground.
Old May 23, 2013 | 05:14 PM
Blackpanther99's Avatar
You should see very good power! 460-470RWHP? Lol
Old May 23, 2013 | 06:46 PM
litle88's Avatar
Love the brazen! It will be around 420!
Old May 24, 2013 | 11:40 AM
20hp from a cam and UDP?
Old May 24, 2013 | 11:10 PM
Ported LS6 Oil Pump
Maverick Man CarbonFiber SAP Grilles
I need to find time to send these off with my hood scoops to get racemesh.
Old May 25, 2013 | 01:36 AM
99Bluz28's Avatar
My guess is 439hp/421trq.
BTW, instead of using a OD alt pulley I'd recommend just bumping the idle up to 900rpm.
Old May 28, 2013 | 07:39 AM
I already bought the OD alternator pulley, plus my whole goal with this car is for it to be the ultimate heads/cam daily driver. A 900rpm idle just doesn't sound like it fits the description.
Old May 28, 2013 | 08:14 AM
redtan's Avatar
If you're going back to the same magical dyno that you hit 400 hp/tq with 3.91s then I will say probably 470ish.
If you go to a more realistic loaded dyno you're probably only going to hit 440 at the most with some 410 tq.
Old May 28, 2013 | 08:47 AM
We've established my car is slightly stronger than your average GTO. I don't know many other GTOs with coated stepped headers and a FAST 102 on the stock cam. Somehow, because I made a whole 10-15 hp over a ported LS2 intake and pacesetters the dynojet reading is fake. This is the same Dyno that read 317whp stock with a hacked crapmaster exhaust and 365whp Intake/Exhaust/Tune. If you want to accuse Lethal Performance SATX of bullshitting the number be my guest.
Old May 28, 2013 | 01:10 PM
stangcobra's Avatar
Dynojets are usually known as being a bit friendly, maybe youll make 450whp on that dyno but on the street your car will be a 430whp car
Old May 28, 2013 | 01:30 PM
Well that's one point of view, but Dynojet seems like the most common around here and thus the standard. People usually say the opposite: "It's a Mustang dyno, so it reads low." Those are really the 2 most widespread choices, and Dynojet seems more popular around here. Also, from what I've heard it's much more difficult to manipulate a Dynojet like you can a Mustang.
It really doesn't matter, the car makes power. Yes there's variation between dynos but do you think it's a 20hp standard deviation? Whenever somebody posts up a dyno number that's slightly higher than average people always say the dyno must have been rigged. Doubt it. Forget what's actually in my setup. Look around there's a thread here with a 415rwhp LS6 Z06.
Old May 29, 2013 | 12:59 AM
TSP 100mm MAF
Old Jun 5, 2013 | 12:23 AM
Nick Williams 102mm DBW TB
BTR .660" Springs with Ti Retainers
IWIS Timing Chain
Old Jun 17, 2013 | 09:57 AM
99twinturbofirebird's Avatar
my guess is 460-470 ... i mean there was a GTO that just put down 475 wheel with just a cam and a fast 102 , that RPM did in delaware
Old Jun 21, 2013 | 07:16 PM
EPS 234/236 .629"/.629" 113+4LSA
Old Jun 21, 2013 | 09:24 PM
oakley6575's Avatar
When do you start assembly?
