PAC 1519 or Manley 221438?
Old May 21, 2013 | 09:49 PM
Mark200's Avatar
Default PAC 1519 or Manley 221438?
As the title says: PAC 1519 or Manley 221438?
The specs are pretty much the same (at least for my application), use will be with a .590 lift cam and 7100 RPM redline (stock LS7) street car only (may seem some very limited road course use).
Of course the PAC is nitrided, and I don't know what the Manley "super finish" is (only that it costs more). Could be nitriding? Would prefer the longest lasting spring of the two.
Old May 21, 2013 | 09:53 PM
low2001gmc's Avatar
MASS seller approved
pacs or even consider the psi ml1511s....
Old May 21, 2013 | 10:27 PM
litle88's Avatar
Have you also considered BTR platinum springs? They have had a "0" failure rate. Just my .2 bud I know they weren't in your list.
Old May 22, 2013 | 07:53 AM
outkast6991's Avatar
I'm running 1519's with .650 lift. Springs were pulled at 3,000 miles and lost no pressure or rate. It seems the key to making a beehive work is a light valve train
Old May 22, 2013 | 03:28 PM
Mark200's Avatar
Thanks for the input, guys. The PSI 1511's aren't going to give me the balance in pressures I'm looking for (seat/open) and all I should need for a 74 gram valve is a beehive (altho Brian has an excellent price on his spring packages).
I am indeed trying to keep the valvetrain light as possible; I'm planning to use a heavier than stock rocker but am saving weight elsewhere to offset it. Regardless, I'm shooting for seat and open pressures about 20 lbs over stock just for a bit of margin (115/316 on the stock spring at the default install height w/.600 lift).
Looks like the nod is going to go to the PAC's. I couldn't find a weight on the Manley springs so I called them up. The guy on the phone didn't know either, but he promptly got one out of stock and weighed it -- 73 grams. How's that for customer service . . . . unfortunately he didn't know what the Manley 'super finish' was, so that remains a mystery. Considering that, and the weight, the 67 gram PAC's seem to be the more desirable of the two for my particular situation.
Old May 22, 2013 | 03:54 PM
Be careful with a heavier rocker. Weight over the nose isn't good for control
Old May 22, 2013 | 04:24 PM
TurboBuick6's Avatar
Like Outcast said, what rockers are you running? If your going with a roller design, you will need duals.
Old May 22, 2013 | 05:39 PM
Mark200's Avatar
Mentioned in another thread, the YT 6670 Yella Terra's for the LS7. See https://ls1tech.com/forums/generatio...la-terras.html
Best I can determine (without handling in person) the nose weight of those are about 12 grams over stock. I can save 5 grams by going to a titanium retainer, and it seems that I can save about 8 grams by going to a lighter spring (some debate on the issue of spring weight importance/impact). So, in my book 12 - 5 - 8 = wash.
That, plus a bit more pressure on the seat and open (over stock) should keep things happy. I think . . . . .
Edit: Unless, the length of the axis of rotation of the rocker nose (1+") gives it a much larger moment of inertia compared to the spring and retainer just moving 0.60" up and down. Hmmmm
