High compression 416 Ls3
Old May 29, 2013 | 02:33 PM
deerslayinrednek's Avatar
Default High compression 416 Ls3
I don't see many higher compression builds around here. I'm planning to build a 416 LS3 for bracket racing and It'll be running on race fuel. Probably run a 4150 setup and solid roller......I haven't decided what heads I'll run yet.....I'm looking for advice/tips, maybe a few examples that some of you have built and the times they run.....thanks
Old May 29, 2013 | 03:56 PM
DietCoke's Avatar
14.72:1 here... 430 LS3 4.072*4.125
In retrospect I would have gone with the 4" crank and just spun it higher, but this is what I got. Made high 560s unlocked... 620+ locked through a 4l80 and 5th gen driveline on E85.
Plan on having some sort of big boy EVAC - either dual -10 or -12 breathers or a vac pump. The big comp LS3s generate a **** ton of crank pressure. I picked up 35 on the dyno with a vac pump.
Old May 29, 2013 | 09:08 PM
That's something I didn't think about, thanks for sharing
Old May 30, 2013 | 03:10 PM
HighspeedLean's Avatar
13.6-1 on mine. 4.080x4.00 combo. Wiseco +5cc dome off the shelf pistons. I had Richard at WCCH do my heads. I havent been to the track yet, but soon.....real soon...next month with any kind of luck! I'm an index racer looking for 9.40's
x2 on the vacuum pump. Before the moroso was installed, light throttle would push oil out the distributor hole.(yes, dist...I use the GMPP front mount setup)
The o-ring around the ford dist wasnt enough to contain the pressure...even at only >2000rpm
Old May 30, 2013 | 05:24 PM
litle88's Avatar
12.25 here....543/525 thru a heavy drivetrain moser 9", 35 spline axles, spool and 4.11's on 93
Old May 30, 2013 | 07:39 PM
mid 9's is impressive, I've love to get into the 9's.......What made you decide to go with a distributor?
Old May 31, 2013 | 09:41 AM
It's what I know....25 years ago when I raced a SBC......4500 carb and crank trigger/dizzy....worked then, should work now
9.40 helps when the race weight is only 2800 pounds
Old May 31, 2013 | 10:38 AM
87silverbullet's Avatar
Here is one from AI that they did for a member on here whose screen name is tireburnin. 13:1 and made a little over 700 horses on e85.
https://ls1tech.com/forums/generatio...ics-video.html
Old Jun 1, 2013 | 10:15 PM
Wildcobra's Avatar
Alot of nice builds I will post my set up soon
Old Jun 2, 2013 | 07:35 PM
S10xGN's Avatar
Wow, 12.25 is way slow! According to the calc's, if your race weight is 3750#, you should be running 10.55 @ 126. Even raising the weigh to 5000# gives 11.50 @ 115...
Old Jun 2, 2013 | 08:24 PM
He meant 12.25:1 compression
Old Jun 2, 2013 | 08:44 PM
Gray86hatch's Avatar
Mine is 11.7 runs on 93 pump. Weight is 2970
Would have ran low .40's but I hurt the converter.
Tim
Old Jun 2, 2013 | 08:46 PM
Also drive it to the track.
Tim
Old Jun 2, 2013 | 09:52 PM
helicoil's Avatar
This is a great engine and a great price. I just have no use for it. It makes right at 775HP. 9.10 1/4 mile times @ 2950-2980#
https://ls1tech.com/forums/parts-cla...-complete.html
Old Jun 2, 2013 | 09:57 PM
82cetuner's Avatar
418 4.07 bore 4.00 stroke, 12.0 compression using -3cc pistions with 30 thou milled heads and a 40 thou head gasket runs 93 octane, makes about 53-550whp threw a ford nine. I also have issues with crank pressure, what kind of vacumme pump should I go with? are the eletric ones worth having and where should I connect it to the valve covers? or the valley cover.
Old Jun 3, 2013 | 08:45 AM
litle88's Avatar
Haha very funny! No I don't run 12's lol
Old Jun 3, 2013 | 08:46 AM
litle88's Avatar
Tim
Thank you lol.
Old Jun 4, 2013 | 08:48 PM
DietCoke's Avatar
I have a GZ. Simple enough kit. Pulls from valley cover, but you can pull from the valve cover(s) as well if you're so inclined.
Old Jun 9, 2013 | 08:19 PM
There's some very nice engines in here.....If anyone else has any post them up
