LS7 Swap C5 Z06
Old Jun 11, 2013 | 01:56 PM
Maxx_Z06's Avatar
Default LS7 Swap C5 Z06
I'm doing some homework on swapping an LS7 in my C5 Z06.
After some research i decided i'd like to keep my wet sump and avoid extra cost and relocating parts. A few articles posted there was no loss of power from not converting over to a dry sump so that's a plus.
If i purchase a bare forged Ls7 block like the one shown here....
http://thompsonmotorsports.net/onlin...products_id=64
I know i would need to supply most the rest of the essentials to complete the motor (heads,cam,pumps,intake manifold etc). How does this add up cost and quality wise vs a complete crate motor or a used one?
http://www.gmpartsdirect.com/results.cfm?partnumber=LS7
What all would be needed?
Old Jun 11, 2013 | 04:58 PM
Skypilot797's Avatar
I just did this a short time ago on my 03 ZO6. I bought a new LS 7 RTA, torque plate honed, bare block and put a forged rotating assembly in (Callies crank, compstar rods, wiseco pistons).
You need a short snout crank as the regular LS 7 crank won't work as its to long. You can find used LS 7 heads at a bargain price and then have them ported along with new valve guides. Shop for a used LS 7 intake and fuel rail and LS 7 injectors. Have the LS 7 intake radically ported. Am using a LS 7 clutch assemble. You will need several harnesses also.
Try calling John @ Texas Speed, he helped put my package together.
Its been worth it, doing fender flares now and 345's on the back.
Best, Tom.
