Aluminum 454 Build
Old Jun 18, 2014 | 06:30 PM
  #461
SHovV's Avatar
Damn. Engine looks fkn bad *** dude!
Old Jun 18, 2014 | 08:30 PM
  #462
Briou's Avatar
Thanks man...a lot of time, sweat, emails, phone calls, and most of all money went into her...
Old Jun 18, 2014 | 10:18 PM
  #463
Sales@Tick's Avatar
IMO it will be fine once you prime it before start up. I wouldn't worry about it at all. When we install camshafts, springs, upgrade trunions, push rods etc. in the shop the car has to sit for a day or two, maybe longer before it gets tuned sometimes.
Same thing happens in that instance as well. We will unhook the coil packs and fuel injectors then turn the motor over for 15 seconds to prime the oil pump and oiling system.
108.5 is also fine as well. Half a crank degree will only change the timing events half a degree.
Old Jun 19, 2014 | 12:53 PM
  #464
Briou's Avatar
Thanks Martin, that definitely puts my mind at ease
Old Jun 19, 2014 | 01:03 PM
  #465
Brian Tooley Racing's Avatar
Lookin good guys!!!
Old Jun 19, 2014 | 08:38 PM
  #466
D9HP's Avatar
Love the pulleys you chose - where did you get all those? My block should be coming back sometime next month!
What size pushrods did you end up running - I may have just missed that.
That intake is unreal. Seriously cannot wait to hear this thing at idle. How hard is that intake to keep tuned?
Old Jun 21, 2014 | 03:08 PM
  #467
Briou's Avatar
The pulley's all came with the Billet Specialties Tru-Trac system....The system also came with the PS pump, alternator, water pump, and A/C compressor....
The pushrods are 7.650" 3/8" manton 3 series
As far as the intake goes, we aren't really sure how hard it will be to keep in tune. In theory it should be pretty easy once we get it set up the first time
Old Jun 21, 2014 | 03:29 PM
  #468
Sales@Tick's Avatar
Push rods are 3/8" diameter .140" wall FWIW.
Old Jun 21, 2014 | 03:48 PM
  #469
Briou's Avatar
^This...Thanks Martin
Old Jun 21, 2014 | 06:23 PM
  #470
ss performance's Avatar
What air filters do intend to used on that intake?
Thanks for sharing all the info on your build!
Old Jun 21, 2014 | 07:27 PM
  #471
LPE 403's Avatar
^^ what you see at the end of the runners is what they consider "filters", lol. No other options...
OP - make sure your vacuum block lines are all the SAME length....FYI.
Looks great, btw
Old Jun 22, 2014 | 10:32 AM
  #472
Briou's Avatar
I remember you saying something about that a while back so I made sure that all of the vacuum lines were the same length...I think the only thing I am using a vacuum reference for is the fuel pressure regulator...well that and the MAP sensor, but that is being referenced off of its own dedicated vacuum rails...
Old Jun 22, 2014 | 09:33 PM
  #473
LPE 403's Avatar
....and your IAC?
Old Jun 22, 2014 | 10:23 PM
  #474
Briou's Avatar
IAC? like Idle air control? I didn't think I would need that using drive by cable? I thought that was only a drive by wire sort of deal...
Old Jun 23, 2014 | 05:54 AM
  #475
LPE 403's Avatar
Yes, idle air. Pretty sure Kinsler doesn't have DbW for these.....
If you already have the secondary vacuum "rails" that reside under the intake (look like fuel rails), you'll be fine in using those for your IAC. I used the vacuum block you showed above for MAP and fuel pressure.
Old Jun 23, 2014 | 08:37 AM
  #476
Briou's Avatar
I currently don't have any IAC anything to my knowlege...Is there a sensor or solenoid that I should have...I am running just the MAP off of the vacuum rails so we can get a better/more accurate reading...I don't know what I need for idle air control though...
Old Jun 23, 2014 | 11:51 AM
  #477
LPE 403's Avatar
You don't have anything. If you'd like it to idle, you might want to look into it.
FAST makes a remote IAC unit that plugs into the GM harness. Same one I used. Made a bracket for it and mounted out of sight. As I said, use the rails below the intake as your source and the vacuum block for MAP and fuel. You'll be glad you did.
Old Jun 23, 2014 | 01:37 PM
  #478
Briou's Avatar
Good call LPE...I don't know how I missed this...
Old Jun 23, 2014 | 07:48 PM
  #479
Briou's Avatar
Is this the thing you were talking about LPE?
http://www.summitracing.com/parts/fst-307016
Old Jun 24, 2014 | 02:08 PM
  #480
Briou's Avatar
hey guys, quick question...What spark plugs do you think I should run on this engine...I have no clue what I need to get and what gap to set them to...
