Aluminum 454 Build
That intake you got is going 2 BLOW YOUR MIND. once dialed in.You got the right group of guys and parts. I'm wanting 2 see 700hp myself from a junkyard 414 Lq9.
Remember the ad.. BO JACKSON KNOWS
UPDATED version... Briou knows
The trans is the 30 spline T-56 (viper style) that comes on the early C6Z's with a RPS full carbon twin disk clutch.
The diff is the 9" Getrag IRS that comes from the factory - beefy.
Once you figure it out you will be able to degree a cam in your sleep.
What are the cam specs?
A lot of guys have FI but the way 700n/a WhINES it can not be repeated...Fact is most cars WON'T hook...unless set up 4 drag but... you can fail safe a car in auto.. FASTw/ wheel spin(new age throttle stop). and go 2 the track and run low-mid 10's and leave the track.. Drive home w. a/c ...
Stop buy the store on the way home. lol...
Whats your cam specs?
Only reason I could see doing it with the head on is if the cams are in the heads.
You are concerned about the cam events in relation to the piston not the valve events to the piston.
Tim
Only reason I could see doing it with the head on is if the cams are in the head.
Tim
Just like taking a rocker ratio change and trying to determine the change in valve lift. It doesn't change to duration of the cam.
Tim
Tim
I'm just offering my two cents. Some people look at that kind of stuff, some don't, but in regards to a previous comment, that's why some of us will degree the cam with the head on.
I attempted to degree the cam with the heads on this weekend....I used a dial indicator extension and put it on the lifter, went through the process as described in the instructions and I came up with 109 ICL....obviously I am going to do it again, and take my time, and use the pushrod and rocker instead of just sending a dial indicator down to the lifter...but it was nice to see that I was only off by one degree initially...
Tim
KCS and I have the same approach, well said.
