Aluminum 454 Build
It is a stock LS3/LS2 front cover....I got both pump and the front cover from Brian Tooley Racing...
600+rwhp or 720-775fwhp. ......oh yeah you got the runner intake 800 hp may be a better target cause U got what it takes..... PUTTING THE RIGHT TEAM AND PARTS 2GETHER = WINNING.
HYD. roller lifter instead of my E-Z roller solid's great lifter and pricey but this lifter in my head would have no up-keep & use my heads 2 there fullest they flow 2....700 lift well lets get there with no lash adj.....Remember bac in OCTOBER...i spoke with the head honcho so time line was 5 months we in May. Callin Monday..
They even kicked in a free t-shirt...
Other parts I got are the oil pan and valley cover gasket, rear cover gasket, map sensor, rear main seal, and iat sensor....
congrats on the ME degree, finished mine about 18yrs ago...seems like a long time ago..
I'm an EE, myself.
Got my crate from ERL today. The block ships out Friday!
Short block (pre assembled)
-block
-rods
-pistons
-crank
-mains
-oil barbell thing
Heads (pre assembled)
-FRH heads
-valves
-springs+retainers
-ARP head studs
Valve train (excluding parts stated above)
-Rockers+bolts
-lifters
-cam
-cam retainer plate+bolts
-cam bolts
-Comp Hex-a-Just Timing set
-Timing chain dampener
Oil System
-oil pump
-oil pickup tube+o-ring
-oil pan+windage tray
Covers
-Front cover
-rear cover
-valley cover
-valve covers
Gaskets+Seals
-Head Gaskets
-front cover gasket
-rear cover gasket
-oil pan gasket
-valley cover gasket
-front main seal
-rear main seal
Sensors
-Cam
-Crank
-oil pressure
-2x knock
-Coolant
-Throttle position sensor
-MAP
-IAT
Things I know I need are pushrods, which I am going to measure once I get the heads on, then I can order a set. I also know I need a set of valve cover gaskets.
Now my questions:
1 What sort of assembly lube should I use for stuff like the cam when assembling the engine?
2 What oil should I soak the lifters in prior to installing them?
3 What is the proper procedure for measuring for pushrod length, (I have a comp pushrod length checker already)?
-block
-rods
-pistons
-crank
-mains
-oil barbell thing
-FRH heads
-valves
-springs+retainers
-ARP head studs
-Rockers+bolts
-lifters
-cam
-cam bolts
Oil System
-oil pump
Covers
-Front cover
-rear cover
-valley cover
-valve covers
Gaskets+Seals
-Head Gaskets
-front cover gasket
-rear cover gasket
-oil pan gasket
-front main seal
-rear main seal
Sensors
-Cam
-Crank
-oil pressure
-2x knock
-Coolant
-MAP
-IAT
Now my questions:
I know it answers 1. and 2. but I am not sure on #3.
I am following along for the ride - looks like a great time. Take lots of pictures, please.
